ios:interface range - is it supported?
kbarve
I am looking for pushing the configuration to multiple switch ports using interface range command.
I am using cisco-ios 4.3.1 package, and I don find cli supporting "range" keyword.
Please let me know if its supported or any alternate example to do such bulk port configuration.
Hi Mark,
Thanks for the reply.
Is there any known alternative?
Like i came across "foreach" in xml template.
Any working example if you can provide, it will great.
Kirti
Mark Swanborough
"range" is a IOS CLI macro. It generates config, but it is not part of the IOS config language.
As such, it's not supported in the Device model. Sorry, that's probably not the answer you are hoping for.
.:|:..:|:. Mark Swanborough | Orchestration & Cloud Platform Architect | Advanced Services | Cisco .:|:..:|:.
Hi Mark,
Kirti
foreach is explained in the NSO developer guide.
Here the example in the guide.
Roque
<ip xmlns="urn:ios">
<route>
<vrf>
<name>VPN{/vpn-number}</name>
<ip-route-forwarding-list foreach="{tunnel}">
<prefix>{network}</prefix>
<mask>{netmask}</mask>
<forwarding-address>10.255.254.{(tunnel-number-1)*4+2}</forwarding-address>
</ip-route-forwarding-list>
</vrf>
</route>
</ip>
