Is it possible to compile a ncs package with just fxs
spudukko
NCSC command to just compile fxs
i see a -f option i would be grateful if someone gave the command.
Assume: the ncs package does not have yang and java files. It has just fxs files.
ncsc
Jan Lindblad
It's certainly a very odd situation to have a package from somewhere that has .fxs files already built, no YANG source, and no instructions of what to do with it. I suggest you go back to your supplier and get clarification on what this is supposed to mean.
There is nothing you can do with ncsc in this situation. The ncsc compiler takes YANG as input and generates different kinds of output, most commonly .fxs files. Without YANG files, ncsc is of no use.
Jan Lindblad
