ncs issue using nso 4.6
romain.guilloux
  I use ncs with nso 4.6 and my following code failed, any advise ? thx
with ncs.maapi.Maapi() as m:
     with ncs.maapi.Session(m, "admin", "CONTEXT_NAME"):
        with m.start_write_trans() as t:
            print root
Error: Bad protocol usage or unexpected retval (21): Library protocol version (67) is not compatible with ConfD protocol version (66)
Jan Lindblad
You are using NSO 4.6, but the application you're building is compiled with NSO 4.7. Make sure your build toolchain is from the same NSO release as the running NSO server.
Jan Lindblad
