Legacy web ui by default
Jason Belk
For NSO 4.5.x+, is there a way to go to Web UI legacy by default by a change in  ncs.conf?
  <webui>
    <enabled>true</enabled>
    <transport>
      <tcp>
        <ip>0.0.0.0</ip>
        <port>8080</port>
      </tcp>
      <ssl>
        <enabled>false</enabled>
        <ip>0.0.0.0</ip>
        <port>8888</port>
        <key-file>${NCS_DIR}/var/ncs/webui/cert/host.key</key-file>
        <cert-file>${NCS_DIR}/var/ncs/webui/cert/host.cert</cert-file>
      </ssl>
    </transport>
    <cgi>
      <php>
      </php>
    </cgi>
  </webui>
alam.bilal
Hi There,
Try "man ncs.conf" and then look for:
       /ncs-config/webui/docroot (string)
           The location of the document root on disk. If this configurable is omited the docroot points to the next generation
           docroot in the NCS distro instead.
This can be used to point the webserver to an alternative URL.
Thanks.
