live-status call for PCRF
previousqna
Level 5
Level 5
Hello everyone,
I am looking for a live-status JSON-RPC call/payload for PCRF device. Do we have support to get device configuration from PCRF device like GW and other devices?  This is what I send in the payload for a GW device:
    "method":"run_action",
    "params":{
        "th":1,
        "path":"/ncs:devices/device{NDC2BSVC3GW01}/live-status/staros-stats:exec/show",
        "params":{"args":"configuration"}
    "jsonrpc":"2.0",
    "id":5
I am looking for something similar for a PCRF device. Thanks for your help.
previousqna
Level 5
Level 5
A device’s config is under /devices/device/<device-name>/config.
A GET equivalent will get the configs for the device (at least whatever has been modelled in the NED).
Is that what is required here?
live-status action is used more to retrieve “operational” data and run exec/show-commands. For this to work the respective NED needs to have this action modelled.
previousqna
Level 5
Level 5
Thanks Bilal for your reply. Yes, this is what I ended up using.
