Making devtools true as a default
RichardD2
Level 4
Level 4
Hi Folks,
In a recent presentation, it was mentioned that it was possible to enable devtools globally in ncs.conf. What path is used to set this? In the documentation, it makes reference to a YANG file, that I haven't been able to find on the server (at least it's not in src/ncs/yang directory with all the other files ncs uses).
         "The ncs.conf file is an XML file that must adhere to the tailf-ncs-config.yang model"
I tried editing ncs.conf like this but it didn't work.
<session>
  <devtools>true</devtools>
</session>
vleijon
I was just been wrong on that one. I knew the others were there, so I didn’t check.
You can still set it true in CDB though using session or user settings.
vleijon
Nabsch
Not all the settings can be set throught ncs.conf . You can check the tailf-ncs-config.yang or do man ncs.conf.
You can for example define the prompt in ncs.conf
As Viktor said , you have to set in the CDB.
Here an example for a specific user
nabil@DESKTOP-8ECTID4:~$ ncs_cli -C  -u admin
User admin last logged in 2022-06-03T22:52:29.72413+00:00, to DESKTOP-8ECTID4, from 127.0.0.1 using cli-console
admin connected from 127.0.0.1 using console on DESKTOP-8ECTID4
admin@ncs# show running-config user
user admin
 session devtools true
admin@ncs# show cli
autowizard            true
complete-on-space     true
devtools              true
display-level         99999999
history               100
idle-timeout          1800
ignore-leading-space  false
leaf-prompting        true
output-file           terminal
paginate              true
prompt1               \u@ncs#
prompt2               \u@ncs(\m)#
screen-length         40
screen-width          156
service prompt config true
show-defaults         false
terminal              xterm-256color
timestamp             disable
admin@ncs#
or  using  session as a global session parameters
admin@ncs# show running-config session
