11-12-2021 01:41 AM
Hi all,
I'm having an issue with hcc and GoBGP
Versions
OS ubuntu 20
nso 5.6.1
hcc ncs-5.6.1-tailf-hcc-project-5.0.2
gobgpd 2.25
when HCC is disable the package loads fine, when i enable the package and add the following configuration
root@ncs# packages reload force
reload-result {
package tailf-hcc
result true
root@ncs#
System message at 2021-11-12 09:35:12...
Subsystem started: tailf_hcc_server
root@ncs#
root@ncs# show packages package tailf-hcc
package-version 5.0.2
description "Package for Tail-f HA Cluster Control Interface"
ncs-min-version [ 5.4 ]
directory /var/opt/ncs/state/packages-in-use/1/tailf-hcc
oper-status up
Ha config
high-availability token cisco1234
high-availability ha-node nso5a address 10.20.1.2 nominal-role master
high-availability ha-node nso5b address 10.30.1.2 nominal-role slave
failover-master true
high-availability settings enable-failover true
high-availability settings reconnect-slaves true
high-availability settings start-up assume-nominal-role true
high-availability settings start-up join-ha true
HCC Config
hcc enabled
hcc vip-address [ 10.10.1.1 ]
hcc bgp node nso5a gobgp-bin-dir /usr/bin/gobgpd as 65020 router-id 10.20.1.2 enabled
neighbor 10.20.1.1 as 65000
password cisco1234 enabled
hcc bgp node nso5b gobgp-bin-dir /usr/bin/gobgpd as 65030 router-id 10.30.1.2 enabled
neighbor 10.30.1.1 as 65000
Result
System message at 2021-11-12 09:35:55...
Subsystem stopped: tailf_hcc_server
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
root@ncs(config)#
nso@ncs# show hcc
Error: application communication failure
nso@ncs#
nso@ncs# show hcc
nso@ncs# show packages
oper-status program-code-error
oper-status error-info [ "tailf_hcc: /var/opt/ncs/state/packages-in-use/1/tailf-hcc/erlang-lib/tailf_hcc/ebin/tailf_hcc.app: failed to start" ]
nso@ncs#
Systemctl output
root@nso-5a-20:~# systemctl status ncs
Docs: file:/usr/share/doc/gobgpd/getting-started.md
any one have any suggestions ?
Yale
P.S I have read tailf_hcc.pdf cover to cover
11-12-2021 02:55 AM
06-02-2022 07:41 PM
You resolved this issue?
