Missing 'cisco-ios' option under ned-settings after upgrade
sphoredd
I upgraded NSO from 4.7 to 5.3, after the upgrade, all the devices of NED setting changed to "Netconf".
I am not seeing 'cisco-ios' option under ned-settings.
admin@ncs(config)# devices device xx-yy-zz ned-settings ?
Possible completions:
use-confirmed-commit Control usage of confirmed commit
use-junos-rollback If set to true use device rollback as a revert strategy.
use-private-candidate Control usage of the private candidate
use-startup Control usage of the startup datastore
use-transaction-id Control usage of fetching the transaction id
use-validate Control usage of validate
admin@ncs(config)#
admin@ncs# show packages package package-version
PACKAGE
NAME VERSION
cisco-aireos-cli-3.3 3.3.21
cisco-asa-cli-6.9 6.9
cisco-ios-cli-3.0 3.0.0.4
cisco-ios-cli-3.8 3.8.0.1
cisco-ios-cli-6.53 6.53
cisco-iosxr-cli-7.25 7.25.2
cisco-nx-cli-5.15 5.15.9
cisco-waas-cli-2.0 2.0.2
citrix-netscaler-gen-4.3 4.3.3
nso-util 1.4.0
admin@ncs#
Could someone help me debugging this issue.
Srinivasa
tcragg1
Migrating from NSO 4 to NSO 5 is more involved than most NSO upgrades. Did you follow the guidance in the NSO CDM Migration Guide in the NSO documentation folder when performing the upgrade?
What is shown as the "device-type" in the configuration for the device? For a cisco-ios CLI NED device, it should be something like the following:
device-type cli ned-id cisco-ios-cli-6.53
Yes, I followed the NSO CDM migration guide. not sure what issue, NEDs not loaded, all the devices NED converted as NETCONF. NED packages loaded and showing package versions but under ned-id "lsa-netconf netconf snmp".
It worked nicely in stage host but facing issue in prod. I had to cancel the upgrade. I will try to upgrade one more time, will update the upgrade status.
Srinivasa
