Missing configuration between NSO and XRv device
Hello All,
Currently, I want to demonstrate NSO feature for deploying Segment Routing using XRv at my customer. I am simulating the SR network using XRv 6.1.3 and NSO 5.1 version. I can successfully register, connect, and sync the XRv devices to/from NSO.
However, I am experiencing some missing config in the NSO compare to XRv running configuration as captured below:
On the XRv device running config, the SR feature is enabled but in NSO it doesn't appear. In fact, I have checked the "sync-from" status in NSO Device Manager and the XRv devices are in Sync status:Screenshot from 2020-02-16 22-38-57.png
Is there any issue with the NED version compatibility or something?
Anybody has the same experience and know how to solve it?
Thanks and Regards,
Rakhmad
cc: @hinwoto
2 Accepted Solutions
tcragg1
Hi Rakhmad,
From the screenshots, it looks like you are using one of the IOS-XR CLI NEDs that is included with the NSO application file (cisco-iosxr-cli-3.5). That NED version is many years old, so it will not have complete feature coverage (for context, the newest released IOS-XR CLI NED is version 7.20).
Looking at the YANG model for a more recent IOS-XR CLI NED, the SR feature appears to be available under router ospf, so you should just need to get a newer NED version to support what you are trying to do.
Just to add to this, the Cisco NEDs (newer ones mentioned) are available for trial use on DevNet:
https://developer.cisco.com/docs/nso/#!getting-nso/getting-nso
this includes the IOS-XR one discussed.
tcragg1
Hi Rakhmad,
Hi Jason and All,
Thanks, it worked now after downloaded the new NED version!
-Rakhmad
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
