[Python] Does anyone have a full working example of completion action in Python
fwclements1
Frequent Visitor
Frequent Visitor
I'm beating my head against a wall here trying to pivot from either erlang or java examples to python.
What I'm in despirate need of is a _working_ example of something akin to the tailf:cli-completion-actionpoint if-complete but in Python.  The goal being tab completion of interface names from within services for a given device.
Can anyone provide anything?  The only hit I'm finding is from @mohamkh7 located here.  However, it doesn't load for me.
fwclements1
Frequent Visitor
Frequent Visitor
I got it working and not as difficult as i originally thought!
Yang model:
module network-link {
  namespace "http://example.com/network-link";
  prefix network-link;
  import tailf-common { prefix tailf; }
  import tailf-ncs { prefix ncs; }
  description
    "Bla bla...";
  revision 2016-01-01 {
    description
      "Initial revision.";
  augment /ncs:services {
    container network-link {
      list connectivity {
        // This represents a physical link between two ports
        key cid;
        leaf cid {
          tailf:info "A unique circuit identifier for a link";
          type string;
        uses ncs:service-data;
        list endpoint {
          key "device interface";
          leaf device {
            type leafref {
              path "/ncs:devices/ncs:device/ncs:name";
          leaf interface {
            type string;
            tailf:cli-completion-actionpoint if-action;
  } // augment /ncs:services {
Python file with simple logging:
import _ncs
import ncs
from ncs.dp import Action
class ActionCallbacks(Action):
    @Action.action
    def cb_action(self, uinfo, name, kp, input, output, trans):
        self.log.info("ActionCallback: ", "cb_action")
    def cb_completion(self, uinfo, cli_style, token, completion_char,
                      kp, cmdpath, cmdparam_id, simpleType, extra):
        self.log.info("ActionCallback: ", "cb_completion({},{},{},{},{},{},{},{},{})".format(
            uinfo, cli_style, token, completion_char, kp, cmdpath, cmdparam_id, simpleType, extra))
        if_list = [(0, 'ge-0/1', None), (0, 'fe-0/0', None), (0, 'ge-0/2', None)]
        _ncs.dp.action_reply_completion(uinfo, if_list)
class IfComplete(ncs.application.Application):
    def setup(self):
        self.log.info('--- if_complete.IFComplete setup')
        self.register_action('if-action', ActionCallbacks)
    def teardown(self):
        self.log.info("-- if_complete.IfComplete teardown")
Output:
admin@ncs(config)# services network-link connectivity 1 endpoint reflector-0 ?
Possible completions:
  fe-0/0  ge-0/1  ge-0/2
fwclements1
Frequent Visitor
Frequent Visitor
Yang model:
  description
    "Bla bla...";
    description
      list connectivity {
        key cid;
        leaf cid {
          type string;
        list endpoint {
          leaf device {
            type leafref {
          leaf interface {
            type string;
import _ncs
import ncs
    @Action.action
    def setup(self):
    def teardown(self):
Output:
