02-10-2019 03:19 AM - edited 03-01-2019 04:16 AM
I have created a netsim device. The NED is iosxr. I have changed RSA keys and I managed to do 'ssh fetch-host-keys' with success.
Then, when I do 'check-sync', I get "info Failed to connect to device poi1: connection refused: null". What can I do about that?
This happens both on MAC and CentOS.
02-11-2019 01:41 PM
Did you connect to the device first and then do a sync-from?
02-11-2019 05:14 PM
No, I did not do that. Do you mean connect to the device like this:
BFINNEMA-M-K25H:tdc-cpe bfinnema$ ncs-netsim cli-i pe1
admin connected from 127.0.0.1 using console on BFINNEMA-M-K25H
BFINNEMA-M-K25H> enable
BFINNEMA-M-K25H#
I still get this:
admin@ncs(config-device-pe1)# sync-from
result false
info Failed to connect to device pe1: connection refused: null
I am using the "Standard" ios-xr NED like this: ncs-4.7.2-cisco-iosxr-7.7.3.signed.bin.
I am wondering whether netsim iosxr devices work only with the cisco-iosxr ned that comes embedded with NSO?? Just a thought..
02-11-2019 05:31 PM
02-21-2019 04:26 AM
Thank you very much for the response.
I have not used any special characters in the password in the authgroup. My netsim ios devices work well. I have the issue only for iosxr netsim devices.
I have received some instructions on how to setup netsim devices, which I will review to make sure I did everything correct. I will get back to you if I need a demo. Thank you for the offer.
02-21-2019 12:06 PM
