NSO 4.7.1.1 WebUI is not coming up
chreddy@cisco.com
I installed NSO version 4.7.1.1 in local mode. The WebUI is NOT coming up.
Issues:
Issue 1: When I point to below address in the browser, I get site can't be reached error:
http://10.78.241.60:8081
Issue 2: CLI mode for same server (10.78.241.60) at port 2024 is not reachable
Snippet of ncs.conf:
<webui>
<enabled>true</enabled>
<transport>
<tcp>
<ip>10.78.241.60</ip>
<port>8081</port>
</tcp>
<cli>
<!-- Use the builtin SSH server -->
<ssh>
<port>2024</port>
</ssh>
commands executed in the device:
[root@localhost ncs-run]# sudo lsof -i:8081
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
ncs.smp 2086 root 77u IPv4 29095 0t0 TCP localhost.localdomain:tproxy (LISTEN)
[root@localhost ncs-run]# netstat -anp | grep 8081
tcp 0 0 10.78.241.60:8081 0.0.0.0:* LISTEN 2086/ncs.smp
snippet of ncs.log:
attached
Can you please suggest how to resolve both of this issues.
hniska
probably a local firewall on you Linux box.
joepak
What happens when you try to enter the http/s address in the browser URL?
