Services that has many devices but has unique enteries
Hi all,
could some one pls point me in the right direction.
just getting started and would like to have a service that adds a VRF to all devices in the network and configures the RD
i have made the services and its does deploy the VRF to all the devices, but how can i set a unique RD for each device and still have them part of that one services
<vrf xmlns="http://example.com/vrf" xmlns:vrf="http://example.com/vrf">
<name>TEST-VRF</name>
<modified>
<devices>C6880</devices>
<devices>XRv-1</devices>
</modified>
<directly-modified>
</directly-modified>
<device-list>C6880</device-list>
<device-list>XRv-1</device-list>
<device>C6880</device>
<device>XRv-1</device>
<description>TEST-VRF</description>
<asn>65000</asn>
<rd>11</rd> - how do u make this unique for each device
</vrf>
Yale
Jan Lindblad
You would need to write some code that allocates unique IDs from a pool or ID server. In theory you might be able to handle this using some smart XPath expressions in your template too, but I would certainly recommend the code approach. If you'd like to see some examples of services that allocate unique values for devices, you can have a look at the resource manager packages are used in examples.ncs/service-provider/virtual-mpls-vpn.
Dan.Sullivan
You can simply build a service in which each device has a separate rd value. For example, the following YANG model actually does something similar. A single VRF service instance that spans multiple devices
list vrf {
description "VRF Service";
key name;
leaf name {
tailf:info "Unique service id";
tailf:cli-allow-range;
type string;
uses ncs:service-data;
ncs:servicepoint vrf-servicepoint;
leaf description {
type string;
list devices {
key name;
leaf name {
type leafref {
path "/svrf:vrf-devices/devices/svrf:name";
leaf route-distinguisher {
type string;
list import-route-target {
key name;
leaf name {
type string;
list export-route-target {
key name;
leaf name {
type string;
leaf import-route-policy {
type string;
leaf export-route-policy {
type string;
leaf max-prefix-limit {
type uint16;
leaf max-prefix-threshold {
type uint16;
Jan Lindblad
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
