NSO 5.5 WEBUI not Reachable
Hi, i am quite new to NSO Product.. i have setup NSO as per Cisco documentation.. However i am unable to access NSO CLI or WEBUI.. after running NCS i got the following output.
DEBUG> 12-Jul-2021::21:53:29.838 localhost ncs[43360]: devel-sls starting SLS server
<INFO> 12-Jul-2021::21:53:29.995 localhost ncs[43360]: - Starting the NCS Smart Licensing Java VM
<INFO> 12-Jul-2021::21:53:30.062 localhost ncs[43360]: - NCS started vsn: 5.5
=INFO REPORT==== 12-Jul-2021::21:53:27.870790 ===
Yaws: Listening to 0.0.0.0:8080 for <1> virtual servers:
- http://localhost:8080 under /home/cisconso/nso-5.5/var/ncs/webui/dist/ncs
<INFO> 12-Jul-2021::21:53:27.871 localhost ncs[43360]: - Starting to listen for WebUI TCP on 0.0.0.0:8080
Appreciate your support to explore further.
THanks
Mohideen.
rogaglia
Typically, this could be either a routing problem in your server or you have a linux firewall enabled blocking these ports.
