NSO Automation
Hello Guys,
in fact I work on the automation of NSO testing with robot framework
I finished the device configuration automation part and here is the code I used and it works
Add IOS loopback interface [Documentation] Add interface to device,
PATCH restconf/data/devices/device=${NETSIM_IOS}/config/tailf-ned-cisco-ios:interface body=${ADD_LBK_IOS}
Integer response status 204
NETSIM_IOS: netsim-io-1
ADD_LBK_IOS: {
    "tailf-ned-cisco-ios:interface": {
        "Loopback": [
                "name": 0
and I will need your help to automate the ncs command below:
administrator@ncs(config)# services SERVICE_NAME TEST001 access-device device-id netsim-io-1 interface-id 0/1
Value for 'services SERVICE_NAME TEST001 delivery-device device-id' [netsim-io-2]:
Value for 'services SERVICE_NAME TEST001 delivery-device interface-id' (<string>): 0/1/2
Value for 'services SERVICE_NAME TEST001 pw-properties customer-name' (<string>): TOTO
Value for 'services SERVICE_NAME TEST001 pw-properties pw-id' (<unsignedInt, 12000 .. 12999>): 12000
Value for 'services SERVICE_NAME TEST001 pw-properties pw-class' [PORT_PW]:
Value for 'services SERVICE_NAME TEST001 pw-properties service-rate' (<unsignedInt, 2 .. 1000>): 500
Value for 'services SERVICE_NAME TEST001 pw-properties vlan-id' (<unsignedShort, 700 .. 799>): 700
thanks a lot
0 Replies 0
