NSO getting started guide examples errors
smolz
Level 5
Level 5
Trying to run through the getting starting guide and getting errors on the first example when doing a `devices connect`
admin@ncs# devices connect
connect-result {
    device c0
    result false
    info Failed to connect to device c0: connection refused: Connection refused (Connection refused)
connect-result {
    device c1
    result false
    info Failed to connect to device c1: connection refused: Connection refused (Connection refused)
connect-result {
    device c2
    result false
    info Failed to connect to device c2: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c0: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c2: connection refused: Connection refused (Connection refused)
admin@ncs# *** ALARM connection-failure: Failed to connect to device c1: connection refused: Connection refused (Connection refused)
admin@ncs#
9 Replies 9
joepak
I assume these are netsim devices.
Did you go to the requested directory and perform the desired steps?
Go to examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios. ### In the install directory, follow the requested path
$ ncs-netsim create-network $NCS_DIR/packages/neds/cisco-ios 3 c
then perform the:
ncs-netsim start ## starts the 3 created netsim devices
And try to connect to the generated netsim devices.
Where exactly did you stop in the documentation?
joepak
$ ncs-setup --netsim-dir ./netsim --dest .## must be defined as well.
Nicklas Wagerth
I just played with the same example and I get the same response as you if I stop my netsim devcies and then try to re-connect.
try "ncs-netsim status" and see if they are started.
i.e.
connect-result {
    device c2
    result false
[ok][2018-12-20 10:27:32]
admin@ncs> *** ALARM connection-failure: Failed to connect to device c1: connection refused: Connection refused
:~/nso-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios$ ncs-netsim status
DEVICE c0
connection refused (status)
DEVICE c1
DEVICE c2
I have tried on both Mac and Ubuntu. See the 2 sections below
On mac:
=> ncs-netsim status
DEVICE c0
./env.sh: line 12: export: `Fusion.app/Contents/Public:/Library/TeX/texbin:/opt/X11/bin:/Library/Frameworks/Mono.framework/Versions/Current/Commands:/usr/local/bin:/Users/smolz/bin:/Users/smolz/.rvm/bin:/Users/smolz/.rvm/bin': not a valid identifier
vsn: 6.7
SMP support: no
Using epoll: no
available modules: backplane,netconf,cdb,cli,snmp,webui
running modules: backplane,netconf,cdb,cli
status: started
namespaces: urn:ietf:params:xml:ns:yang:iana-crypt-hash prefix:ianach exported to: all
            urn:ietf:params:xml:ns:yang:ietf-inet-types prefix:inet exported to: all
            urn:ietf:params:xml:ns:yang:ietf-netconf-acm prefix:nacm exported to: none
            urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring prefix:ncm exported to: all
            urn:ietf:params:xml:ns:yang:ietf-netconf-notifications prefix:ncn exported to: all
            urn:ietf:params:xml:ns:yang:ietf-restconf prefix:rc exported to: rest
            urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring prefix:rcmon exported to: all
            urn:ietf:params:xml:ns:yang:ietf-yang-library prefix:yanglib exported to: netconf,rest
            urn:ietf:params:xml:ns:yang:ietf-yang-patch prefix:ypatch exported to: rest
            urn:ietf:params:xml:ns:yang:ietf-yang-types prefix:yang exported to: all
            http://tail-f.com/ns/aaa/1.1 prefix:aaa exported to: none
            http://tail-f.com/yang/acm prefix:tacm exported to: all
            http://tail-f.com/yang/common prefix:tailf exported to: all
            http://tail-f.com/yang/common-monitoring prefix:tfcg exported to: all
            http://tail-f.com/ns/common/query prefix:tfcq exported to: all
            http://tail-f.com/yang/confd-monitoring prefix:tfcm exported to: all
            http://tail-f.com/ns/kicker prefix:kicker exported to: all
            urn:ios prefix:ios exported to: all
            http://tail-f.com/yang/netconf-monitoring prefix:tncm exported to: all
            http://tail-f.com/ns/progress prefix:progress exported to: all
            http://tail-f.com/ns/rollback prefix:rollback exported to: rest,netconf,maapi
            http://tail-f.com/ns/webui prefix:webui exported to: all
            http://tail-f.com/yang/xsd-types prefix:xs exported to: all
YANG data models:
  module: iana-crypt-hash revision: 2014-08-06
    namespace: urn:ietf:params:xml:ns:yang:iana-crypt-hash
    prefix: ianach
    exported to: all
  module: ietf-inet-types revision: 2013-07-15
    namespace: urn:ietf:params:xml:ns:yang:ietf-inet-types
    prefix: inet
    exported to: all
  module: ietf-netconf-acm revision: 2012-02-22
    namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-acm
    prefix: nacm
    exported to: none
  module: ietf-netconf-monitoring revision: 2010-10-04
    namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring
    prefix: ncm
    exported to: all
  module: ietf-netconf-notifications revision: 2012-02-06
    namespace: urn:ietf:params:xml:ns:yang:ietf-netconf-notifications
    prefix: ncn
    exported to: all
  module: ietf-restconf revision: 2017-01-26
    namespace: urn:ietf:params:xml:ns:yang:ietf-restconf
    prefix: rc
    exported to: rest
  module: ietf-restconf-monitoring revision: 2017-01-26
    namespace: urn:ietf:params:xml:ns:yang:ietf-restconf-monitoring
    prefix: rcmon
    exported to: all
  module: ietf-yang-library revision: 2016-06-21
    namespace: urn:ietf:params:xml:ns:yang:ietf-yang-library
    prefix: yanglib
  module: ietf-yang-patch revision: 2017-02-22
    namespace: urn:ietf:params:xml:ns:yang:ietf-yang-patch
    prefix: ypatch
    exported to: rest
  module: ietf-yang-types revision: 2013-07-15
    namespace: urn:ietf:params:xml:ns:yang:ietf-yang-types
    prefix: yang
    exported to: all
  module: tailf-aaa revision: 2015-06-16
    namespace: http://tail-f.com/ns/aaa/1.1
    prefix: aaa
    exported to: none
  module: tailf-acm revision: 2013-03-07
    namespace: http://tail-f.com/yang/acm
    prefix: tacm
    exported to: all
  module: tailf-common revision: 2018-04-19
    namespace: http://tail-f.com/yang/common
    prefix: tailf
    exported to: all
  module: tailf-common-monitoring revision: 2013-06-14
    namespace: http://tail-f.com/yang/common-monitoring
    prefix: tfcg
    exported to: all
  module: tailf-common-query revision: 2017-12-15
    namespace: http://tail-f.com/ns/common/query
    prefix: tfcq
    exported to: all
  module: tailf-confd-monitoring revision: 2013-06-14
    namespace: http://tail-f.com/yang/confd-monitoring
    prefix: tfcm
    exported to: all
  module: tailf-kicker revision: 2017-09-28
    namespace: http://tail-f.com/ns/kicker
    prefix: kicker
    exported to: all
  module: tailf-ned-cisco-ios revision: 2014-02-12
    namespace: urn:ios
    prefix: ios
    exported to: all
  module: tailf-netconf-monitoring revision: 2016-11-24
    namespace: http://tail-f.com/yang/netconf-monitoring
    prefix: tncm
    exported to: all
  module: tailf-progress revision: 2018-06-21
    namespace: http://tail-f.com/ns/progress
    prefix: progress
    exported to: all
  module: tailf-rollback revision: 2018-01-12
    namespace: http://tail-f.com/ns/rollback
    prefix: rollback
  module: tailf-webui revision: 2013-03-07
    namespace: http://tail-f.com/ns/webui
    prefix: webui
    exported to: all
  module: tailf-xsd-types revision: 2017-11-20
    namespace: http://tail-f.com/yang/xsd-types
    prefix: xs
    exported to: all
user sessions:
system sessions:
  sessionId=1 2018-12-20 08:52:14 [email protected] system/system
       no locks set
       no transactions
  sessionId=10 2018-12-20 08:52:14 [email protected] system/system
       no locks set
       no transactions
  sessionId=11 2018-12-20 08:52:14 [email protected] system/system
       no locks set
       no transactions
  sessionId=12 2018-12-20 08:52:14 [email protected] system/system
       no locks set
       transactions:
          tid=7 db=running mode=read
callpoints:
validation points:
actionpoints:
typepoints:
notification stream replay support:
SNMP inform delivery callbacks:
SNMP notification subscriptions:
authentication callback:
  not enabled
authorization callbacks:
  not enabled
error formatting callbacks:
partial running locks:
partial candidate locks:
partial startup locks:
cdb:
  current transaction id: 1545-324734-697436
  running:
      ram size: 17.3 kB
      read locks: 0
      write lock: unset
  startup:
      filename: ./cdb/A.cdb
      disk size: 2.0 kB
      ram size: 17.1 kB
      read locks: 0
      write lock: unset
  operational:
      filename: ./cdb/O.cdb
      disk size: 4 bytes
      ram size: 136 bytes
      subscription lock: unset
  no pending subscription notifications
  no registered cdb clients
tts alloc:
  43175 40:50:20 64:280:0 72:35:0 120:10:0 176:57:246
DEVICE c1
vsn: 6.7
SMP support: no
Using epoll: no
status: started
YANG data models:
    prefix: ianach
    exported to: all
    prefix: inet
    exported to: all
    prefix: nacm
    exported to: none
    prefix: ncm
    exported to: all
    prefix: ncn
    exported to: all
    prefix: rc
    exported to: rest
    prefix: rcmon
    exported to: all
    prefix: yanglib
    prefix: ypatch
    exported to: rest
    prefix: yang
    exported to: all
    prefix: aaa
    exported to: none
    prefix: tacm
    exported to: all
    prefix: tailf
    exported to: all
    prefix: tfcg
    exported to: all
    prefix: tfcq
    exported to: all
    prefix: tfcm
    exported to: all
    prefix: kicker
    exported to: all
    namespace: urn:ios
    prefix: ios
    exported to: all
    prefix: tncm
    exported to: all
    prefix: progress
    exported to: all
    prefix: rollback
    prefix: webui
    exported to: all
    prefix: xs
    exported to: all
user sessions:
system sessions:
  sessionId=1 2018-12-20 08:52:15 [email protected] system/system
       no locks set
       no transactions
  sessionId=10 2018-12-20 08:52:15 [email protected] system/system
       no locks set
       no transactions
  sessionId=11 2018-12-20 08:52:15 [email protected] system/system
       no locks set
       no transactions
  sessionId=12 2018-12-20 08:52:15 [email protected] system/system
       no locks set
       transactions:
callpoints:
validation points:
actionpoints:
typepoints:
  not enabled
  not enabled
cdb:
  current transaction id: 1545-324735-936486
  running:
      ram size: 17.2 kB
      read locks: 0
      write lock: unset
  startup:
      disk size: 2.0 kB
      ram size: 17.1 kB
      read locks: 0
      write lock: unset
  operational:
      disk size: 4 bytes
      ram size: 136 bytes
tts alloc:
  43191 40:50:20 64:284:0 72:30:0 120:11:0 176:57:246
DEVICE c2
vsn: 6.7
SMP support: no
Using epoll: no
status: started
YANG data models:
    prefix: ianach
    exported to: all
    prefix: inet
    exported to: all
    prefix: nacm
    exported to: none
    prefix: ncm
    exported to: all
    prefix: ncn
    exported to: all
    prefix: rc
    exported to: rest
    prefix: rcmon
    exported to: all
    prefix: yanglib
    prefix: ypatch
    exported to: rest
    prefix: yang
    exported to: all
    prefix: aaa
    exported to: none
    prefix: tacm
    exported to: all
    prefix: tailf
    exported to: all
    prefix: tfcg
    exported to: all
    prefix: tfcq
    exported to: all
    prefix: tfcm
    exported to: all
    prefix: kicker
    exported to: all
    namespace: urn:ios
    prefix: ios
    exported to: all
    prefix: tncm
    exported to: all
    prefix: progress
    exported to: all
    prefix: rollback
    prefix: webui
    exported to: all
    prefix: xs
    exported to: all
user sessions:
system sessions:
  sessionId=1 2018-12-20 08:52:16 [email protected] system/system
       no locks set
       no transactions
  sessionId=10 2018-12-20 08:52:17 [email protected] system/system
       no locks set
       no transactions
  sessionId=11 2018-12-20 08:52:17 [email protected] system/system
       no locks set
       no transactions
  sessionId=12 2018-12-20 08:52:17 [email protected] system/system
       no locks set
       transactions:
callpoints:
validation points:
actionpoints:
typepoints:
  not enabled
  not enabled
cdb:
  current transaction id: 1545-324737-174921
  running:
      ram size: 17.1 kB
      read locks: 0
      write lock: unset
  startup:
      disk size: 2.0 kB
      ram size: 17.1 kB
      read locks: 0
      write lock: unset
  operational:
      disk size: 4 bytes
      ram size: 136 bytes
tts alloc:
  43039 40:50:20 64:285:0 72:32:0 120:8:0 176:57:246
_______________________________________
| ~/ncs-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios @ iMacistan (smolz)
On Ubuntu:
ubuntu:~/nso-4.7/examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios$ ncs-netsim status
DEVICE c0
DEVICE c1
DEVICE c2
joepak
Hi, so i think i know what the issue is/was.
Josephs-MacBook-Pro:1-simulated-cisco-ios jleepak$ ncs-setup --netsim-dir ./netsim --dest .
Using netsim dir ./netsim
I stopped NSO due to my previous instance being up via ncs --stop. Started NSO
Josephs-MacBook-Pro:1-simulated-cisco-ios jleepak$ ncs_cli -C -u admin
admin connected from 127.0.0.1 using console on Josephs-MacBook-Pro.local
admin@ncs# show devices list
NAME  ADDRESS    DESCRIPTION  NED ID     ADMIN STATE
c0    127.0.0.1  -            cisco-ios  unlocked
c1    127.0.0.1  -            cisco-ios  unlocked
c2    127.0.0.1  -            cisco-ios  unlocked
connect-result {
    device c0
    result true
    info (admin) Connected to c0 - 127.0.0.1:10022
What I think you did was forgetting to set up the netsim-dir in the examples.ncs/getting-started/using-ncs/1-simulated-cisco-ios directory.
You must remain in the directory of the desired samples.
Not true. I did follow the examples. set the netsim folder to the examples folder.
I got the same error , connection refused.
Here is what I did:
JOEPAK-M-21L8:using-ncs jleepak$ pwd
/Users/jleepak/nso/471/install/examples.ncs/getting-started/using-ncs
JOEPAK-M-21L8:using-ncs jleepak$ ls
0-hello-world 4-netconf-device 8-ssh-keys
1-simulated-cisco-ios 5-snmp-alarm-northbound README
2-real-device-cisco-ios 6-access-lists
3-real-device-juniper 7-scripting
JOEPAK-M-21L8:using-ncs jleepak$ cd 1-simulated-cisco-ios/
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ls
README README.netsim ncs-cdb netsim scripts
README.ncs logs ncs.conf packages state
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ pwd
/Users/jleepak/nso/471/install/examples.ncs/getting-started/using-ncs/1-simulated-ciscoJOJOEPAK-M-JOEPAK-M-JOEPAJOEPJOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs-setup --netsim-dir ./netsim --dest .
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs --stop
ncsJOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs_cli -u admin
admin connected from 127.0.0.1 using console on JOEPAK-M-21L8
admin@ncs> switch cli
Can you show me step by step how you are performing this? Can you perform 'pwd' and proceed with trying to generate the samples?
connect-result {
device c0
result false
connect-result {
device c1
result false
connect-result {
device c2
result false
admin@ncs# exit
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs-netsim restart
DEVICE c0 already STOPPED
DEVICE c1 already STOPPED
DEVICE c2 already STOPPED
DEVICE c0 RESET
DEVICE c1 RESET
DEVICE c2 RESET
DEVICE c0 OK STARTED
DEVICE c1 OK STARTED
DEVICE c2 OK STARTED
connect-result {
device c0
result true
connect-result {
device c1
result true
info (admin) Connected to c1 - 127.0.0.1:10023
connect-result {
device c2
result true
info (admin) Connected to c2 - 127.0.0.1:10024
joepak
For reference as well:
JOEPAK-M-21L8:1-simulated-cisco-ios jleepak$ ncs-netsim status
DEVICE c0
vsn: 6.7.2
SMP support: no
Using epoll: no
status: started
YANG data models:
prefix: ianach
exported to: all
prefix: inet
exported to: all
prefix: nacm
exported to: none
prefix: ncm
exported to: all
prefix: ncn
exported to: all
prefix: rc
exported to: rest
prefix: rcmon
exported to: all
prefix: yanglib
prefix: ypatch
exported to: rest
prefix: yang
exported to: all
module: tailf-aaa revision: 2018-09-12
prefix: aaa
exported to: none
prefix: tacm
exported to: all
module: tailf-common revision: 2018-11-12
prefix: tailf
exported to: all
prefix: tfcg
exported to: all
prefix: tfcq
exported to: all
prefix: tfcm
exported to: all
prefix: kicker
exported to: all
namespace: urn:ios
prefix: ios
exported to: all
prefix: tncm
exported to: all
prefix: progress
exported to: all
prefix: rollback
prefix: webui
exported to: all
prefix: xs
exported to: all
user sessions:
system sessions:
sessionId=1 2019-02-11 15:50:56 [email protected] system/system
no locks set
no transactions
sessionId=10 2019-02-11 15:50:57 [email protected] system/system
no locks set
no transactions
sessionId=11 2019-02-11 15:50:57 [email protected] system/system
no locks set
no transactions
sessionId=12 2019-02-11 15:50:57 [email protected] system/system
no locks set
transactions:
callpoints:
validation points:
actionpoints:
typepoints:
not enabled
not enabled
cdb:
current transaction id: 1549-921857-158880
running:
ram size: 17.2 kB
read locks: 0
write lock: unset
startup:
disk size: 2.0 kB
ram size: 17.1 kB
read locks: 0
write lock: unset
operational:
disk size: 4 bytes
ram size: 136 bytes
tts alloc:
43263 40:50:20 64:274:0 72:40:0 120:11:0 176:57:246
I see this in your status:
DEVICE c0
vsn: 6.7
I'm not sure if that affects the netsim, but i notice i do not have that in my status output. What device are you trying to run the samples on?
