Showing results forĀ
Search instead forĀ
Did you mean:Ā
NSO Orchestrator Lab
T-129
I have two issues with the NSO Devnet lab. It centres around the merge. Any advice and guidance would be greatly appreciated.
5 Replies 5
Marcel Zehnder
Seems like your "inventory" is not correct - can you please post the content of nso-device-config.txt (cat /home/developer/nso-device-config.txt)
Here's the output below.
I tried the config on 10.10.20.50 and it worked this time.
Marcel Zehnder
Ok great (that's what i would expect, because your inventory is looking fine).
