NSO Rollback History Length
Hi i know NSO will only hold history for the last 500 commits, but is this number configurable where can i configure it ?
Yale
found it :)
ramkraja
Not sure where the number 500 is from. You can configure it in ncs.conf, under /ncs-config/rollback/history-size
$ man ncs.conf
/ncs-config/rollback/history-size (uint32) [35]
Number of old configurations to save.
/Ram
