NSO, show devices brief via RESTCONF
bfinnema
When doing this:
curl --location --request GET 'http://localhost:8080/restconf/data/tailf-ncs:devices' \
--header 'Accept: application/yang-data+json' \
--header 'Cache-Control: no-cache' \
--header 'Authorization: Basic YWRtaW46YWRtaW4=' \
--data-raw ''
I get enormous amounts of data, including complete config of each device. I just want a list o devices similar to running "show devices brief" on NSO. How can I do that with RESTCONF?
rogaglia
You should review RFC8040 query parameters:
https://tools.ietf.org/html/rfc8040#section-4.8
   | Name          | Methods | Description                             |
   | content       | GET,    | Select config and/or non-config data    |
   |               | HEAD    | resources                               |
   | depth         | GET,    | Request limited subtree depth in the    |
   |               | HEAD    | reply content                           |
   | fields        | GET,    | Request a subset of the target resource |
   |               | HEAD    | contents                                |
   | filter        | GET,    | Boolean notification filter for event   |
   |               | HEAD    | stream resources                        |
   | insert        | POST,   | Insertion mode for "ordered-by user"    |
   |               | PUT     | data resources                          |
   | point         | POST,   | Insertion point for "ordered-by user"   |
   | start-time    | GET,    | Replay buffer start time for event      |
   | stop-time     | GET,    | Replay buffer stop time for event       |
   | with-defaults | GET,    | Control the retrieval of default values |
   |               | HEAD    |                                         |
omz
http://localhost:8080/restconf/data/tailf-ncs:devices/device
http://localhost:8080/restconf/data/tailf-ncs:devices/device=ios0/config
curl -i -u admin:admin http://localhost:8080/restconf/operations/devices/device=ios0/live-status/tailf-ned-cisco-ios-stats:exec/any -X POST -H 'Accept: application/yang-data+json' -H 'Content-Type: application/yang-data+json' -d "{\"input\": {\"args\": \"show devices brief\"}}"
perander
As Roque stated, review thew RESTCONF query parameters; specifically "depth" and
"fields" are useful for pruning data.
Note though that there might be better performace using the RESTCONF Query API
(it might be called REST Query API in documentation). If it's a one shot query without
the need for pagination use "immediate-query", where the query response contains
the results in the payload; thus eliminiating the need for an explicit "fetch-query-result".
curl --location 'https://localhost:4464/restconf/data/tailf-ncs:devices/device?depth=1&fields=name' \
--header 'Accept: application/vnd.yang.collection+xml' \
--header 'Content-Type: application/vnd.yang.collection+xml' \
response like,
    <device xmlns="http://tail-f.com/ns/ncs"  xmlns:ncs="http://tail-f.com/ns/ncs">
        <name>pe-0</name>
    </device>
