Package reload-result with “info –ERROR—”
Fantolino
After package reload some packages results in error:
cisco@ncs> request packages reload
reload-result {
    package Itential Tools
    result false
    info --ERROR--
reload-result {
    package cisco-ios
    result false
    info --ERROR--
reload-result {
    package cisco-iosxr
    result false
    info --ERROR--
The errored package statuses result ‘UP’, though.
cisco@ncs> show packages package oper-status
        PACKAGE
                    PROGRAM                                                        META     FILE
                    CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME            UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
Itential Tools  X   -        -              -        -        -        -           -        -      -
cisco-ios       X   -        -              -        -        -        -           -        -      -
cisco-iosxr     X   -        -              -        -        -        -           -        -      -
What is the problem? How can I solve it?
gmuloche
at this stage difficult to give a good answer. For both NEDs (and I believe should be the same for Itential package) you may have some information in the Java logs (ncs-java-vm.log file). Otherwise look at devel.log as well if anything pops up there. Do you have any other Java package (the ones you are not mentioning / are not erroring)
The packages appears up do you see any issue using them?
yfherzog
Might be that you're running out of memory?
Thanx for the replay. I don’t think there memory shortage.
Jason Belk
One thing I see is that you are logged in as your local computer user into NSO "cisco@ncs", rather than a user which has admin access to the application. The default user for NSO local install is admin. You can login as admin by doing
ncs_cli -C -u admin
instead of just doing
ncs_cli -C
The -C gives you the Cisco style CLI (if you don't have it it is Junos style).
gmuloche
