Problem with configuring NSO device-type cli ned-id
wesleyderks
I am trying to configure the NSO in the lab NSO Fundamentals, but I get stuck when I add the device edge-sw01. When I follow the steps one off the commands isn't recognized. This are the steps what on the site is writen:
devices device edge-sw01
address 10.10.20.172
authgroup labadmin
device-type cli ned-id cisco-ios-cli-6.44
device-type cli protocol telnet
ssh host-key-verification none commit
All the commands are accepted, only device-type cli ned-id cisco-ios-cli-6.44 isn't possible to add. Also I tryed the load merge command from a copy off the config from 10.10.20.49, but I get the same error on line 5 what is the same command.
The only 3 options what I have got are these:
admin@ncs(config-device-edge-sw01)# device-type cli ned-id ?
Description: The NED Identity
Possible completions:
[lsa-netconf] lsa-netconf netconf snmp
What I am doing wrong? Hopefully anyone has a answer for my problem, thanks anyway for reading
Gr Wesley
So, the ncs-setup command will create a new NSO 'run-time' directory to use with a NSO 'local' install.
Generally the run-time directory is created outside of the NSO product install directory.
This command above (I didn't see this command in the lab example):
ncs-setup --dest ${NCS_DIR}/packages/neds
created a new directory called 'neds' as a NSO run-time directory, overwriting the NEDs provided with your NSO distribution.
Subsequent linking to neds in that directory which are no longer there - so your links are going nowhere so NSO has nothing to load.
So you'll need to re-install NSO to get those NEDs back and then proceed as follows:
I keep a directory called Projects where I put all my NSO run-time directories, say it's at ~/Projects:
$ cd ~/Projects
Projects$ source ~/NCS/releases/nso-5.3.1/ncsrc
Projects$ echo $NCS_DIR
/Users/lmanor/NCS/releases/nso-5.3.1
Projects$
Projects$ ncs-setup --package $NCS_DIR/packages/neds/cisco-ios-cli-3.8 --package $NCS_DIR/packages/neds/cisco-nx-cli-3.0 --package $NCS_DIR/packages/neds/cisco-iosxr-cli-3.5 --package $NCS_DIR/packages/neds/cisco-asa-cli-6.6 --dest nso-runtime
Projects$ cd nso-runtime
nso-runtime$ ls
README.ncs logs ncs-cdb ncs.conf packages scripts state
nso-runtime$ cd packages/
packages$ ls -altr
total 0
lrwxr-xr-x 1 lmanor staff 68 Sep 25 12:07 cisco-ios-cli-3.8 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-ios-cli-3.8
lrwxr-xr-x 1 lmanor staff 67 Sep 25 12:07 cisco-nx-cli-3.0 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-nx-cli-3.0
lrwxr-xr-x 1 lmanor staff 70 Sep 25 12:07 cisco-iosxr-cli-3.5 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-iosxr-cli-3.5
lrwxr-xr-x 1 lmanor staff 68 Sep 25 12:07 cisco-asa-cli-6.6 -> /Users/lmanor/NCS/releases/nso-5.3.1/packages/neds/cisco-asa-cli-6.6
drwxr-xr-x 6 lmanor staff 192 Sep 25 12:07 .
drwxr-xr-x 9 lmanor staff 288 Sep 25 12:07 ..
packages$ ls cisco-asa-cli-6.6
CHANGES LICENSES.nedcom build-meta-data.xml netsim private-jar src
LICENSE README load-dir package-meta-data.xml shared-jar
Then from the nso run-time directory, start NSO:
packages$ cd ..
nso-runtime$ ncs
nso-runtime$ ncs_cli -u admin
admin connected from 127.0.0.1 using console on LMANOR-M-24MR
admin@ncs>
admin@ncs> show packages package oper-status
PACKAGE
PROGRAM META FILE
CODE JAVA PYTHON BAD NCS PACKAGE PACKAGE CIRCULAR DATA LOAD ERROR
NAME UP ERROR UNINITIALIZED UNINITIALIZED VERSION NAME VERSION DEPENDENCY ERROR ERROR INFO
cisco-asa-cli-6.6 X - - - - - - - - - -
cisco-ios-cli-3.8 X - - - - - - - - - -
cisco-iosxr-cli-3.5 X - - - - - - - - - -
cisco-nx-cli-3.0 X - - - - - - - - - -
8 Replies 8
lmanor
It looks like you may not have the cisco-ios-cli-6.44 NED package (or any other NED for that matter) loaded into NSO.
If you show packages what is loaded into NSO:
From operational cli mode:
admin@ncs# show packages package oper-status
Hello Imanor
Thanks for the reply. It seems that is the problem that the NED packages aren't loaded in the NSO
% No entries found.
I thought that I loaded the NED packages in a early state with these commands
ncs-setup --package nso/packages/neds/cisco-ios-cli-6.44 \
> --package nso/packages/neds/cisco-nx-cli-5.15 \
> --package nso/packages/neds/cisco-iosxr-cli-7.20 \
> --package nso/packages/neds/cisco-asa-cli-6.8 \
> --dest nso-instance
After these commands I saw in the directory nso-instance these logical links created
lrwxrwxrwx 1 developer docker 26 Sep 25 04:48 cisco-asa-cli-6.8 -> packages/cisco-asa-cli-6.8
lrwxrwxrwx 1 developer docker 27 Sep 25 04:48 cisco-ios-cli-6.44 -> packages/cisco-ios-cli-6.44
lrwxrwxrwx 1 developer docker 29 Sep 25 04:48 cisco-iosxr-cli-7.20 -> packages/cisco-iosxr-cli-7.20
lrwxrwxrwx 1 developer docker 26 Sep 25 04:48 cisco-nx-cli-5.15 -> packages/cisco-nx-cli-5.15
Did I forget something or isn't the configuration correct? I follewed 3 times the steps, but I don't see what is wrong.
$ cd ~/Projects
Projects$
nso-runtime$ ls
packages$ ls -altr
total 0
packages$ cd ..
nso-runtime$ ncs
admin@ncs>
PACKAGE
PROGRAM META FILE
Thanks for the reply, at this moment there is a maintenance window, so I will try the solution after the weekend
greatings Wesley
Thanks Imanor,
I tryed the steps again today and everything is working fine
Gr Wesley
RiekCyber
You just have to copy the NED package you need from  ./ncs-6.0/packages/neds/ to  ./ncs-run/packages/
Then You have to reload the package in the cli with the command  admin@ncs# packages reload
>> https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2019/pdf/LABSPG-2442-LG.pdf .
There is no NED package in the ncs-run directory by default.
Truly yours,
Thanks your suggestion did it for me. Have a great day!
Jesus Illescas
If you are starting with NSO, I highly recommend to take a look at these learning labs.
- https://developer.cisco.com/learning/labs/learn-nso-with-netsim/
- https://developer.cisco.com/learning/tracks/get_started_with_nso/
They go step-by-step to getting started with NSO. There you can find detailed guides and you can practice with a live environment directly on the web browser.
The NSO you can find there is based on the official NSO container.
Let us know any suggestion, we are actively update them.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
