ā07-30-2018 03:30 AM
I want to upgrade all NED's to NCS 4.7 but I'm stuck with the NX NED.
When I set the symlink towards the correct NED directory, and after I did a make clean,make. I receive the following error when requesting to reload all packages inside NSO.
The following logging is visible in /var/log/ncs/ncs.log
<DEBUG> 30-Jul-2018::04:05:42.366 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-ios/load-dir/tailf-ned-secrets.fxs <DEBUG> 30-Jul-2018::04:05:42.368 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/fortinet-fortios/load-dir/tailf-ned-fortinet-fortios-non-vdom.fxs <DEBUG> 30-Jul-2018::04:05:42.557 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/fortinet-fortios/load-dir/tailf-ned-fortinet-fortios-meta.fxs <DEBUG> 30-Jul-2018::04:05:42.559 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/fortinet-fortios/load-dir/tailf-ned-fortinet-fortios-id.fxs <DEBUG> 30-Jul-2018::04:05:42.561 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/fortinet-fortios/load-dir/tailf-ned-fortinet-fortios.fxs <DEBUG> 30-Jul-2018::04:05:42.677 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-ios/load-dir/cliparser-extensions-v11.fxs <DEBUG> 30-Jul-2018::04:05:42.677 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-nx/load-dir/cliparser-extensions-v10.fxs <DEBUG> 30-Jul-2018::04:05:42.678 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-nx/load-dir/tailf-ned-cisco-nx-stats.fxs <DEBUG> 30-Jul-2018::04:05:42.693 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-nx/load-dir/tailf-ned-cisco-nx-meta.fxs <DEBUG> 30-Jul-2018::04:05:42.698 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-nx/load-dir/tailf-ned-cisco-nx-id.fxs <DEBUG> 30-Jul-2018::04:05:42.699 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-nx/load-dir/tailf-ned-cisco-nx.fxs <DEBUG> 30-Jul-2018::04:05:42.961 localhost ncs[5939]: - Loading file /var/opt/ncs/state/packages-in-use/1/cisco-ios/load-dir/tailf-ned-cisco-ios-oper.fxs <DEBUG> 30-Jul-2018::04:05:42.963 localhost ncs[5939]: - Skipping file /var/opt/ncs/state/packages-in-use/1/fortinet-fortios/load-dir/cliparser-extensions-v11.fxs: namespace already loaded <CRIT> 30-Jul-2018::04:05:51.356 localhost ncs[5939]: - The prefix cli is defined in both http://tail-f.com/ned/cliparser and http://tail-f.com/ned/cliparser_v11. <INFO> 30-Jul-2018::04:11:38.840 localhost ncs[5988]: - Enabling error log
For some reason cli is defines in multiple places. I tried to install ncs-4.7-cisco-nx-5.6.
Also I tried to use ncs-4.7-cisco-nx-5.5.2 and ncs-4.6.1-cisco-nx-5.6 but without any luck.
What could be wrong, and what is the right approach to troubleshoot this?
ā08-01-2018 07:38 AM
Hi - did you resolve this issue? i've seen no updates.
Also, while you did mention the NSO version (upgrading to 4.7) you did not (as i recall) list any of the NED versions that you are trying to bring in. You'll note that there are indicated incompatibilities between OLD and NEW versions of some NEDs dude to re-organization of the Java code.
Please list your NED versions (or check the CHANGES) files -- that would be my first step.
thanks
gregg
