REST call filtering
Andre Gustavo Albuquerque
I want to filter the result of a REST GET call to suppress some containers in the output.
Consider the YANG model below as example:
container networks {
  list network {
    key name;
    leaf name {
      type string;
    container test1 {
     ...content suppressed for brevity...
    container test2 {
My question is how to fetch all networks and displaying only the content from the container test1, suppressing others (e.g.: test2)?
Thanks in advance
alam.bilal
Here is an example (I haven't tested it for your model, so you may need to tweak):
URL: http://localhost:8080/api/query
HTTP Method: POST
Payload:
<start-query xmlns="http://tail-f.com/ns/tailf-rest-query">
<foreach>
/networks/network
</foreach>
<select>
<label>test1</label>
<expression>test1</expression>
<result-type>inline</result-type> <== inline as we want a sub-tree
</select>
</start-query>
Response:
<start-query-result>
<query-handle>2</query-handle> <== Note the handle returned
</start-query-result>
To Fetch Result:
HTTP Method: POST
Payload:
<fetch-query-result xmlns="http://tail-f.com/ns/tailf-rest-query">
<query-handle>2</query-handle> <== supply back the previously returned handle
</fetch-query-result>
Response:
alam.bilal
Hi There,
Take a look at the Query API (nso_northbound.pdf). It allows for filtering and selecting the nodes to be retrieved.
Thanks.
alam.bilal
HTTP Method: POST
Payload:
<foreach>
/networks/network
</foreach>
<select>
</select>
</start-query>
Response:
To Fetch Result:
HTTP Method: POST
Payload:
Response:
Thank you. I will try it.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
