Custom configuration in NSO-managed block
SCadilhac1
Hello community,
I've created a NSO infrastructure service which pushes the basic BGP configuration to my devices, and establishes the needed interior peerings between them.
On a few devices, I manually added external BGP neighborships.
What can I do to prevent the infrastructure service from removing these manual sessions when it is re-deployed? Without modelling these BGP sessions in the service if possible.
Thank you,
Sylvain
Dan.Sullivan
Hi Sylvain,
In general, NSO should only remove what it added unless you explicitly tell it to delete something.
-Dan
Dan.Sullivan
Hi Sylvain,
-Dan
Hi Dan,
Thank you. Thanks to your response I understood the behavior I was observing was wrong. Probably some old dependencies due to successive code upgrades. I've cleared the configurations and re-deployed the current packages, and it's now working as expected.
Sylvain
