RESTConf call taking very long and cuts response
csgeek
I'm trying to get some basic meta data about all devices that drives my app logic.  When I try to run the following request:
curl -H "Content-Type: application/yang-data+json" -H "Accepts: application/yang-data+json" -u "user:secret" --connect-timeout 3600 "https://nso-east.es.net/restconf/data/tailf-ncs:devices?depth=2&fields=device(name);device(platform(model));device(platform(name));device(module);device(module);device(live-status(tailf-ned-alu-sr-stats:chassis(serial-number)))"
The request seems to take a very long time and even with an extended timeout it still gets truncated and doesn't return the full data.
Is there a way to optimize this call? I saw posts about setting content=config but that doesn't give me all the data I need.  Is there a page that shows all the options for the content type?
Any help is appreciated.
Alexander Stevenson
Hello @csgeek,
Please check out these two discussions regarding slow and incomplete RESTConf responses:
RESTCONF vs REST API huge difference between response times
https://community.cisco.com/t5/nso-developer-hub-discussions/restconf-vs-rest-api-huge-difference-between-response-times/td-p/4016980
NSO RESTCONF API call returning incomplete response
https://community.cisco.com/t5/nso-developer-hub-discussions/nso-restconf-api-call-returning-incomplete-response/td-p/4426618
Hope these help!
perander
Hi!
Is the response just cut and the connection closed or is there
missing content?
How many devices are in the list?
What version of NSO are you using?
EDIT: Have you tried the RESTCONF Query API? It might have better performance.
