Template deployement
lallaa108
I have New to NSO and Started Playing around with the Application. I have Tried to  configure a Simple QOS template for IOS XR and XE devices. Below is my config. It works perfect for IOS XR devices, but for XE devices I am getting the following error
'devices device PE1 config class-map VPAN-CORE-CONTROL' is not configured
Please help
Below is the template
devices template DEFAULT_TEMPLETE
config
  cisco-ios-xr:class-map VPAN-CORE-CONTROL
   match dscp [ cs6 cs7 50 52 54 58 60 62 ]
   match mpls experimental topmost [ 6 7 ]
   match precedence [ internet network ]
  cisco-ios-xr:class-map VPAN-CORE-BUSINESS
   match dscp [ cs2 af21 af22 af23 ]
   match mpls experimental topmost [ 2 ]
   match precedence [ immediate ]
  cisco-ios-xr:class-map VPAN-CORE-STANDARD
   match dscp [ default 2 4 6 ]
   match mpls experimental topmost [ 0 ]
   match precedence [ routine ]
  cisco-ios-xr:class-map VPAN-CORE-SCAVENGER
   match dscp [ cs1 af11 af12 af13 ]
   match mpls experimental topmost [ 1 ]
   match precedence [ priority ]
  cisco-ios-xr:class-map VPAN-CORE-INTERACTIVE
   match dscp [ cs3 af31 af32 af33 ]
   match mpls experimental topmost [ 3 ]
   match precedence [ flash ]
  cisco-ios-xr:class-map default
  ! after default
  cisco-ios-xr:class-map VPAN-CORE-VIDEO
   match dscp [ cs4 af41 af42 af43 ]
   match mpls experimental topmost [ 4 ]
   match precedence [ flash-override ]
  ! after VPAN-CORE-VIDEO
  cisco-ios-xr:class-map VPAN-CORE-VOICE
   match dscp [ cs5 ef 42 44 ]
   match mpls experimental topmost [ 5 ]
   match precedence [ critical ]
  ! after VPAN-CORE-VOICE
  cisco-ios-xr:class-map class-default
  cisco-ios-xr:policy-map VPAN-CORE-OUT
   class class-ref VPAN-CORE-CONTROL
    bandwidth percent 4
    random-detect exp 6
     min-threshold      20
     min-threshold-unit ms
     max-threshold      100
     max-threshold-unit ms
    random-detect exp 7
     min-threshold      20
     max-threshold      100
   class class-ref VPAN-CORE-VOICE
    police-rate-unit police rate percent 10
    police-rate-unit police rate conform-action transmit
    police-rate-unit police rate exceed-action drop
    priority level 1
   class class-ref VPAN-CORE-VIDEO
    police-rate-unit police rate percent 20
    priority level 2
   class class-ref VPAN-CORE-INTERACTIVE
    bandwidth percent 35
    random-detect exp 3
     min-threshold      20
     max-threshold      100
   class class-ref VPAN-CORE-BUSINESS
    bandwidth percent 20
    random-detect exp 2
     min-threshold      20
     max-threshold      100
   class class-ref VPAN-CORE-STANDARD
    bandwidth percent 9
    random-detect exp 0
     min-threshold      20
     max-threshold      100
   class class-ref VPAN-CORE-SCAVENGER
    bandwidth percent 1
    random-detect exp 1
     min-threshold      2
     max-threshold      5
  ios:class-map VPAN-CORE-STANDARD
   match ip precedence [ 0 ]
  ios:class-map VPAN-CORE-VIDEO
   match ip precedence [ 4 ]
  ios:class-map VPAN-CORE-VOICE
   match ip precedence [ 5 ]
  ios:class-map VPAN-CORE-CONTROL
   match ip precedence [ 6 7 ]
  ios:class-map VPAN-CORE-INTERACTIVE
   match ip precedence [ 3 ]
  ios:policy-map VPAN-CORE-OUT
   class VPAN-CORE-CONTROL
    bandwidth percent 4
   class VPAN-CORE-VOICE
    police-cir-percent police cir percent percentage 10
    priority
   class VPAN-CORE-VIDEO
    police-cir-percent police cir percent percentage 20
    priority
   class VPAN-CORE-INTERACTIVE
   class VPAN-CORE-SCAVENGER
    bandwidth percent 1
   class VPAN-CORE-STANDARD
    bandwidth percent 9
   class class-default
    bandwidth percent 1
Jan Lindblad
So at which point do you get this message? Is this a message you get when you deploy a service that expects VPAN-CORE-CONTROL to already be provisioned on the device? Did you apply your template to PE1, and if so, do you see VPAN-CORE-CONTROL being part of the config?
Hi Jan
This error occurs after I do a commit dry-run on the device . I have done Templates with only IOS configurations , I get the same result. When I do a show config I see the full config displayed to me (please see below)
admin@ncs(config)# devices device PE1 apply-template template-name DEFAULT_TEMPLETE
apply-template-result {
    device PE1
    result ok
admin@ncs(config)# commit dry-run
Aborted: 'devices device PE1 config class-map VPAN-CORE-CONTROL' is not configured
admin@ncs(config)# show config
devices device PE1
config
   match dscp 50
   match dscp 52
   match dscp 54
   match dscp 58
   match dscp 60
   match dscp 62
   match dscp cs6
   match dscp cs7
   match ip precedence 6 7
   match dscp af31
   match dscp af32
   match dscp af33
   match dscp cs3
   match ip precedence 3
   match mpls experimental topmost 3
   match dscp 2
   match dscp 4
   match dscp 6
   match dscp default
   match ip precedence 0
   match mpls experimental topmost 0
   match dscp af41
   match dscp af42
   match dscp af43
   match dscp cs4
   match ip precedence 4
   match mpls experimental topmost 4
   match dscp 42
   match dscp 44
   match dscp cs5
   match dscp ef
   match ip precedence 5
   match mpls experimental topmost 5
    bandwidth percent 4
    bandwidth percent 1
    bandwidth percent 9
    police cir percent 20
    priority
    police cir percent 10
    priority
   class class-default
    bandwidth percent 1
admin@ncs(config)#
I think this is my Issue. if I do manuel config I get to add options after IOS:CLASS-MAP. I do not get that Option then I configure a template. I don't know I have only been Playing with the System for 5 days now
admin@ncs(config)# devices device CE1 config
admin@ncs(config-config)# ios:class-map ?
Possible completions:
  aol       - Configure CBAC class-map for IM-AOL protocol
  edonkey   - eDonkey
  fasttrack - FastTrack Traffic - KaZaA, Morpheus, Grokster...
  gnutella  - Gnutella Version2 Traffic - BearShare, Shareeza, Morpheus ...
  http      - Configure CBAC class-map for HTTP protocol
  imap      - Configure CBAC class-map for IMAP protocol
  kazaa2    - Kazaa Version 2
  match-all - Logical-AND all matching statements under this classmap
  match-any - Logical-OR all matching statements under this classmap
  msnmsgr   - Configure CBAC class-map for IM-MSN protocol
  pop3      - Configure CBAC class-map for POP3 protocol
  smtp      - Configure CBAC class-map for SMTP protocol
  sunrpc    - Configure CBAC class-map for RPC protocol
  type      - type of the class-map
  ymsgr     - Configure CBAC class-map for IM-YAHOO protocol
