There is moderate amount of data generated in the CDB after south-bound locking the device in the scale test bed. "sync-to" command is failing with "NXAPI failure :: Connection reset" error to N9K
jayark
I have moderate amount of data generated in the CDB after south-bound locking the device. “sync-to” command is failingt with the below error: -
version 7.0(3)I7(2)
boot nxos bootflash:/nxos.7.0.3.I7.2.bin
[edit]
nso:admin@VTC1-45K (config)# request devices device VTS_45K_TOR2 sync-to
result false
info External error in the NED implementation for device VTS_45K_TOR2: NXAPI failure ::
Connection reset
[ok][2018-03-01 00:17:49]
Below error from : nso trace log for 1 tor.
<< 28-Feb-2018::19:48:22.090 SET_TIMEOUT
<< 28-Feb-2018::19:49:22.365 ERROR: External error in the NED implementation for device
VTS_45K_TOR1: NXAPI failure :: Connection reset
Show quoted text
<< 28-Feb-2018::19:49:22.366 CLOSED
Please share the connection settings which can be configured to prevent sync-to failure?
Tried altering the below timeout settings, did not see any difference.
           <connect-timeout>120</connect-timeout>
            <read-timeout>120</read-timeout>
            <write-timeout>120</write-timeout>
Any pointers would be helpful since it is very urgent!
frjansso
I'd recommend you enable NED tracing for the device:
set device device VTS_45K_TOR2  trace raw
commit
request devices devices VTS_45K_TOR2  disconnect
then retry the sync-to.
Files of interest will be:
logs/ncs-java-vm.log, see if there are any NED errors here
logs/ned-...VTS_45K_TOR2.. , see what the NED/device actually does.
frjansso
commit
