06-05-2017 12:05 PM - edited 03-01-2019 03:51 AM
Hey, I would like to create test deployment in NSO where some networks are ephemeral.
When VNF-Info contains vnfd-connection-point references, like in the example below, then NSO expects that all network-id are pre-existing in Openstack. I would like to create MyCSR-1-ext and myCSR-2-ext networks in Openstack. How I can define this in VNF-Info?
Thanks!
Kali
<vnfd-connection-point>
<id>management-ext</id>
<network-name>os-management-net-0</network-name>
</vnfd-connection-point>
<id>MyCSR-1-ext</id>
<network-name>orch-inside-net-0</network-name>
<id>MyCSR-2-ext</id>
<network-name>orch-outside-net-0</network-name>
Solved! Go to Solution.
06-06-2017 09:05 AM
Yes, checkout additional-network in VNF info. Specify the network parameters there, and refer to the name in the vnfd-connection point:
vnfd-connection-point left {
network-name volvo-MyDeployment-inside-net;
additional-network volvo-MyDeployment-inside-net {
subnet {
network 192.168.1.0/30;
06-06-2017 09:05 AM
subnet {
06-07-2017 01:48 AM
Thank you very much! Works like charm.
Btw. is there any way to configure the dhcp allocation range for the subnet? Similar to ESC XML?
