yanger: Correct formatting of swagger format?
DTtb
Hi all,
I tried to generate a swagger api documentation based on a ncs service with yanger.
How to interpret the swagger output? Is this the correct output?
I cannot find any information about the ncs service inside the swagger output.
YANG model:
module: testservice
  augment /ncs:services:
    +--rw testservice* [infra-type infra-location]
       +---x check-sync
       |  +---w input
       |  |  +---w outformat?                  outformat4
       |  |  +---w (depth)?
       |  |  |  +--:(deep)
[Omitted output]
Command:
yanger --format=swagger --output=/tmp/testservice.swagger -t expand --swagger-host 127.0.0.1:8080 --swagger-basepath /restconf /var/opt/ncs/packages/testservice/src/yang/testservice.yang
Output:
Common information:
$ ncs --version
4.7.2.1
$ yanger --version
yanger 1.0
Thanks.
gmuloche
you are augmenting the /ncs:services container in your model so you need to get the swagger output of this module to see your service.
this is working using a package test:
yanger --swagger-path-filter=/data/tailf-ncs-services:services/test:test --format=swagger -t expand --output=/tmp/testservice.swagger --swagger-host 127.0.0.1:8080  /var/nso-5.2.0.3/src/ncs/yang/tailf-ncs.yang /path/to/file/test.yang
(Note with the current version of yanger - using yanger 1.0 coming with NSO 5.2.0.3 here this works for me because I don't have any "data" in my augmenting module as swagger currently accept only one data module for swagger plugin)
My package yang model looks like:
module test {
  namespace "http://example.com/test";
  prefix test;
  import ietf-inet-types {
    prefix inet;
  import tailf-common {
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Bla bla...";
  revision 2016-01-01 {
    description
      "Initial revision.";
  augment "/ncs:services" {
    list test {
      description "This is an RFS skeleton service";
      key name;
      leaf name {
        tailf:info "Unique service id";
        tailf:cli-allow-range;
        type string;
      uses ncs:service-data;
      ncs:servicepoint test-servicepoint;
      // may replace this with other ways of refering to the devices.
      leaf-list device {
        type leafref {
          path "/ncs:devices/ncs:device/ncs:name";
      // replace with your own stuff here
      leaf dummy {
        type inet:ipv4-address;
gmuloche
module test {
  prefix test;
    prefix inet;
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Bla bla...";
    description
    list test {
      key name;
      leaf name {
        type string;
      leaf-list device {
        type leafref {
      leaf dummy {
