09-03-2019 12:24 AM
Hi all,
I tried to generate a swagger api documentation based on a ncs service with yanger.
How to interpret the swagger output? Is this the correct output?
I cannot find any information about the ncs service inside the swagger output.
YANG model:
module: testservice
augment /ncs:services:
+--rw testservice* [infra-type infra-location]
+---x check-sync
| +---w input
| | +---w outformat? outformat4
| | +---w (depth)?
| | | +--:(deep)
[Omitted output]
Command:
yanger --format=swagger --output=/tmp/testservice.swagger -t expand --swagger-host 127.0.0.1:8080 --swagger-basepath /restconf /var/opt/ncs/packages/testservice/src/yang/testservice.yang
Output:
Common information:
$ ncs --version 4.7.2.1 $ yanger --version yanger 1.0
Thanks.
Solved! Go to Solution.
09-03-2019 08:43 AM
you are augmenting the /ncs:services container in your model so you need to get the swagger output of this module to see your service.
this is working using a package test:
yanger --swagger-path-filter=/data/tailf-ncs-services:services/test:test --format=swagger -t expand --output=/tmp/testservice.swagger --swagger-host 127.0.0.1:8080 /var/nso-5.2.0.3/src/ncs/yang/tailf-ncs.yang /path/to/file/test.yang
(Note with the current version of yanger - using yanger 1.0 coming with NSO 5.2.0.3 here this works for me because I don't have any "data" in my augmenting module as swagger currently accept only one data module for swagger plugin)
My package yang model looks like:
module test {
namespace "http://example.com/test";
prefix test;
import ietf-inet-types {
prefix inet;
import tailf-common {
prefix tailf;
import tailf-ncs {
prefix ncs;
description
"Bla bla...";
revision 2016-01-01 {
description
"Initial revision.";
augment "/ncs:services" {
list test {
description "This is an RFS skeleton service";
key name;
leaf name {
tailf:info "Unique service id";
tailf:cli-allow-range;
type string;
uses ncs:service-data;
ncs:servicepoint test-servicepoint;
// may replace this with other ways of refering to the devices.
leaf-list device {
type leafref {
path "/ncs:devices/ncs:device/ncs:name";
// replace with your own stuff here
leaf dummy {
type inet:ipv4-address;
09-03-2019 08:43 AM
module test {
prefix test;
prefix inet;
prefix tailf;
import tailf-ncs {
prefix ncs;
description
"Bla bla...";
description
list test {
key name;
leaf name {
type string;
leaf-list device {
type leafref {
leaf dummy {
