IEEE 802.3u and IEEE 802.3z Compatibility
fgasimzade
Level 4
Level 4
Hello everyone!
Does anyone know if these 2 fiber optic SFPs are compatible with each other?
We have and old HP J4853A transceiver which is 802.3u and Cisco SFP LX Module which is 802.3z
Thank you!
fgasimzade
Level 4
Level 4
Another follow up question
Will HP J4853A and Cisco SFP Module 100BASE-FX modules be compatible?
Thank you!
Hello
For your reference, when talking about fiber transceiver you want to check the following details:
- There exists two modes: Single mode, and multi-mode, you want to make sure both use the same mode.
- Wavelenght, there are 850nm, 950nm, 1310nm.... You need to make sure it matches.
- No all switches/routers support all types of modules, so check the following compatibility matrix to make sure hardware and tranceiver are compatible.
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Regards.
Wilson B.
