100MB over SMF?
RoboCisco
I have two buildings which are connected via Single Mode Fiber (SMF).
In building A, I have a WS-3750X-12S-S.
In Building B, I have a device which ONLY supports 100MB connections, either TX or FX.
Constraints:  I'm stuck with the SMF fiber between these two buildings, and I'm stuck with a 100MB device in building B.  Can't change it.
Other than using media converters on both sides, how can I connect these two?
Since the 3750X is a Gig switch, the only SFP I see which can do 100MB in a GIG SFP slot is a GLC-GE-100FX, but its for MMF. (Reference:http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/100MB_Tx_Matrix.html)
-Rob
Marvin Rhoads
I'd agree with your analysis - this is a case where a media converter is the indicated solution (given the constraints you've outlined).
Marvin Rhoads
jmcgrady1
Its curious that Cisco doesn't offer a 100mb SFP certified for operation over single mode. Their LH 1000mb module can run on single or multimode fibre over short distances. However their GLC-GE-100FX is listed as multimode only.
I realize that this thread is more than 5 years old, but Cisco does offer several 100M single mode options:
GLC-FE-100LX to 10km
GLC-FE-100EX to 40km
GLC-FE-100ZX to 80km
GLC-FE-100BX-D and GLC-FE-100BX-U for a single fiber connection to 10km
They're just not supported on the WS-3750X-12S-S switch listed above.  You could probably get a third-party optics company to make one that would work though.
