10Gbase-SR Current - Low Alarm
F3nrir
Running into an issue where I am getting alerts notifying me of a low current alarm on my Nexus 3ks for a tranceiver that is connected to an admin down interface. Is this an alarm bug?
Here is the alarm:
Current                          Alarms                 Warnings
Measurement           High         Low        High        Low
Current 0.00 mA -- 10.50 mA 2.50 mA 10.50 mA 2.50 mA
balaji.bandi
is this a cisco SFP in the port or non cisco SFP
can you post the output of
show interface ethernet x/x transc
shiw ver
BB
Here is the output let me know if this is what you are looking for.
    transceiver is present
    type is 10Gbase-SR
    name is CISCO-AVAGO
    part number is SFBR-709SMZ-CS1
    revision is G4.1
   nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um OM2 fiber is 82 m
    Link length supported for 62.5/125um fiber is 26 m
    Link length supported for 50/125um OM3 fiber is 300 m
    cisco id is 3
    cisco extended id number is 4
    cisco part number is 10-2415-03
    cisco product id is SFP-10G-SR
    cisco vendor id is V03
type is 10Gbase-SR
name is CISCO-AVAGO
revision is G4.1
cisco id is 3
I think this bug is related to your problem, you should disregard these transceiver alarms.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCve74342
Alvaro
