08-22-2018 08:04 AM
I have a need to have a 10gigbit access port on a 2960x 24ts-l running 15.2(6). With the proper SFP+, is it possible to configure a port this way?
Solved! Go to Solution.
08-22-2018 08:23 AM
(hmmm where did my reply go? )
SFP optics do not support 10Gb. So to answer your question, you will not be able to configure a 10Gb switchport on your 2960X-TS.
cheers,
Seb.
08-22-2018 08:08 AM - edited 08-22-2018 08:09 AM
Hi there,
The 2960X-24TS does not support SFP+. You need a 2960X-24TD .
cheers,
Seb.
08-22-2018 08:20 AM
The previous person replied that the 2960x does not support SFP+. He was probably correct, however I meant to just say SFP. I need to know if I can provision an access port that is 10gig using one of the (4) SFP ports that are available to me on this device. Anybody got anything for me?
08-22-2018 08:23 AM
cheers,
Seb.
08-22-2018 08:23 AM
SFP ports do not support 10 Gbps connections - only 1 Gbps (or lower with the proper transceiver type assuming it's compatible with the switch).
A 10 Gbps access port would require an SFP+ type port and associated compatible transceiver.
08-29-2018 08:42 AM
