ASR1001-X with GLC-LH-SMD not coming up
billybong
Hi all, Strange problem i have a ASR1001-X with GLC-LH-SMD not coming up, the GLC-LH-SMD are seen by the ASR but the link stays down
but with GLC-SX-MM's installed the link comes up and is fine
i have tested the LH's in other devices and they are fine anyone had this problem?
Router#sh ve
Cisco IOS XE Software, Version 16.06.01
Cisco IOS Software [Everest], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M)
, Version 16.6.1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Sat 22-Jul-17 05:48 by mcpre
Router#
Router#sh inv
NAME: "Chassis", DESCR: "Cisco ASR1001-X Chassis"
PID: ASR1001-X , VID: V03 , SN:
NAME: "Power Supply Module 0", DESCR: "Cisco ASR1001-X AC Power Supply"
PID: ASR1001-X-PWR-AC , VID: V01 , SN:
NAME: "Power Supply Module 1", DESCR: "Cisco ASR1001-X AC Power Supply"
NAME: "Fan Tray", DESCR: "Cisco ASR1001-X Fan Tray"
PID: ASR1001-X-FANTRAY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ASR1001-X SPA Interface Processor"
PID: ASR1001-X , VID: , SN:
NAME: "SPA subslot 0/0", DESCR: "Built-in GE SPA with 2 port 10G and 6 port 1G I
nterfaces"
PID: BUILT-IN-2T+6X1GE , VID: , SN:
NAME: "subslot 0/0 transceiver 2", DESCR: "GE LX"
PID: GLC-LH-SMD , VID: V01 , SN:
about the only thing that I can think of would be, on the ASR interface, try
no negotiation auto
if you haven't already, and see what happens.
I don't have a lot of instances to compare to, but on each of my ASR1ks, that have a fiber SFP, they are all set to no negotiate auto. I wouldn't necessarily think that would matter but maybe there is some nuance with optical vs RJ SFPs.
22 Replies 22
balaji.bandi
1. is that port not come up or going to error disabled mode.
2. are you using Single mode cable or multimode ?
3. what is remove end SFP ?
try adjusting speeds or no speed nogiations ? is this usefull ?
Also worth looking for your version there is bug reported :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg95411/?rfs=iqvred
BB
Thanks for the quick reply
its not coming up
Router#sh ip int brie
Te0/0/0 unassigned YES NVRAM administratively down down
Te0/0/1 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/1 192.168.1.100 YES NVRAM down down
GigabitEthernet0/0/2 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/3 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/4 unassigned YES NVRAM administratively down down
GigabitEthernet0/0/5 unassigned YES NVRAM administratively down down
GigabitEthernet0 unassigned YES NVRAM administratively down down
I'm using a multimode cable
no option for speed negotiation
      Router(config-if)#no speed negotiation
% Invalid input detected at '^' marker.
The bug is not what im experiencing
I noticed the media type is unknown but after poking around, Cisco say this is cosmetic
Router#sh int g0/0/1
GigabitEthernet0/0/1 is down, line protocol is down
Hardware is BUILT-IN-2T+6X1GE, address is 380e.4dc8.fe83 (bia 380e.4dc8.fe83)
Internet address is 192.168.1.100/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
output flow-control is on, input flow-control is on
I'm out of ideas
when you say multimode cable, do you mean just a jumper to another device, or do you mean multimode to an LIU (IE-fiber up a riser, or to a different location/building)?
as far as I recall, with the LH optics, using multimode fiber, you would need a modal conditioning jumper. I believe that is noted in the SFP spec sheet. Or, at least it used to be.
It's just a jumper cable, but the LH's and the same cable work when I connected to switches together which makes me think I'm missing something
ok, fair enough. what does your interface configs look like, on both sides? seems more of a link layer problem than physical layer
Not in the office at the moment, but other side is same down down
anyone ?
can you post what is otehr side device. and interface status on both the side and config.
Can you post below output from both the devices.
show run interface x/x
show interface x/x
show interface x/x capa
show ver
BB
asr1001-x#
asr1001-x#sh run int g0/0/1
Building configuration...
Current configuration : 96 bytes
interface GigabitEthernet0/0/1
ip address 192.168.1.100 255.255.255.0
negotiation auto
end
asr1001-x#sh int g0/0/1
Full Duplex, 1000Mbps, link type is auto, media type is LX
Last input 00:01:22, output 00:01:54, output hang never
Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
1076 packets input, 98347 bytes, 0 no buffer
Received 420 broadcasts (0 IP multicasts)
1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 654 multicast, 0 pause input
7 packets output, 482 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
59 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
asr1001-x#sh int g0/0/1 capa
asr1001-x#sh ve
Cisco IOS-XE software, Copyright (c) 2005-2017 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
asr1001-x uptime is 2 hours, 11 minutes
Uptime for this control processor is 2 hours, 12 minutes
System returned to ROM by reload
System image file is "bootflash:asr1001x-universalk9.16.06.01.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
License Level: adventerprise
Next reload license Level: adventerprise
cisco ASR1001-X (1NG) processor (revision 1NG) with 3863781K/6147K bytes of memo
ry.
Processor board ID FXS2129Q0GT
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
0K bytes of WebUI ODM Files at webui:.
asr1001-x#
switch# sh run int g2/1/1
Current configuration : 38 bytes
interface GigabitEthernet2/1/1
end
switch#sh int g2/1/1
GigabitEthernet2/1/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 0007.7d27.8f31 (bia 0007.7d27.8f31)
Keepalive not set
Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseLX SFP
input flow-control is off, output flow-control is unsupported
Last input 22:50:41, output 00:04:45, output hang never
2270502 packets input, 878195063 bytes, 0 no buffer
Received 23482 broadcasts (19266 multicasts)
0 watchdog, 19266 multicast, 0 pause input
4420724 packets output, 3968013415 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
switch# sh int g2/1/1 capa
Model: WS-C3750X-48P
Type: 1000BaseLX SFP
Speed: 1000
Duplex: full
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),
tx-(4q3t) (3t: Two configurable values and one fixed.)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
switch#
no negotiation auto
you absolute legend , that's fixed it :)
sorry jumped the gun, saw the link come up on asr but when i checked the other end of the link it was still down down
MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
Keepalive not set
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
0 packets output, 0 bytes, 0 underruns
switch#
anyone?
This is what i have suggested other post the check the negotiation and speed, any way  coming back to post down at Switch side.
it is Layer 2 port ( make it either Layer 3 port)
for testing
shut
no switchport
ip address 192.168.1.101 255.255.255.0
no shut
lets us know how it goes.
BB
