ā03-27-2023 07:37 AM
My end user uses small business switches CBS350-24FP-4G and is connecting with C9200-24P. GE Transceiver for SMB is MGBSX1 and from C9200 I use GLC-SX-MM. It wont link to each other unless I trick them by unplug and plug back other gbic from catalyst side. Does anyone knows about this issue?
Solved! Go to Solution.
ā04-03-2023 04:36 PM
Not sure.
IOS-XE is riddled with optic module bugs. If one version fixes it, another version will re-introduce the same bug.
ā03-27-2023 08:24 AM
Any error message on the 9200 side?
ā03-27-2023 08:27 AM
no error
ā03-27-2023 08:44 AM
- Following https://tmgmatrix.cisco.com/?tpid=142 , GLC-SX-MM is not supported on your 9200 checkout : https://tmgmatrix.cisco.com/?npf=341
M.
ā03-28-2023 05:08 AM
Thanks for the info , I ordered two GLC-SX-MMD. I will update here with results.
ā04-03-2023 10:25 AM
I tried GLC-SX-MMD and still the same issue. Any other suggestion?
ā03-27-2023 05:12 PM
Yes, it is a very widely known issue about optics and IOS-XE.
Cold reboot is the most common "recommended" workaround.
ā03-28-2023 05:10 AM
This is troubleshooting 101, I have tried and didn't work. Thanks
ā03-28-2023 02:37 PM
Loop the link to each other. Does the port go up?
ā03-29-2023 06:14 AM
I put GLS-SX-MM in both side and the link comes up .
ā03-29-2023 04:05 PM
What firmware is the 9200 on?
ā03-30-2023 04:55 AM
17.6.4
ā03-30-2023 03:11 PM
Please try either 17.6.5 or 17.9.3.
ā04-03-2023 10:26 AM
Do you think 17.6.5 will fix my issue ?
Not sure.
