Cisco C9300-NM-2C 10Gp Suppor
ZK916
We are considering buying the C9300-NM-2C network module card for our C9300X switch. The specs. on the data sheet doesn't' specify if this network module supports 10Gb port speed.I was wondering if anyone has and document that says that the network module supports 10G or has used this type of network module at 10G?
Thanks in advance.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
balaji.bandi
C9300-NM-2C - this is Hundres gig model, you need QSFP for this to use 10G  - yes i did test 10G and it works.
BB
ZK916
Awesome!
Thank you, @balaji.bandi
https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2019/pdf/BRKARC-3863.pdf
check this ciscolive
C9300-NM-2C <<- I dont see this module for 9300
check the slide and select right module
