Cisco GLC-LH-SMD 1GB/s 1000BASE
need to know sfp compatibility with another vendor
balaji.bandi
Personally i would suggest to both side should be same, But some time Other vendor Like telco they have their own equiment and SFP, as long as it meet wave legnth should be ok to communicate each other.
BB
balaji.bandi
BB
Many thanks
Joseph W. Doherty
If optical transceivers on both sides are for same standard, and fiber run also meets standard, usually brand of transceivers shouldn't matter.
Whether a Cisco SFP port will work with a brand X transceiver is a different matter.
