Cisco: Low Optical Transmit Power
octuslimb
Does this point to an issue with an SFP?
We have a 4500-x vss stack, through which runs the heartbeat for a bunch of vrrp groups upstream, both routers have been going active due to loss of heartbeat.
One of the switch uplinks has a tx power of -10db on the switch, but router upstream is showing healthy rx signal of -5db.
mgrabovs
To check if the values are under the proper intervals, we would have to check under these commands:
show hw-module subslot X/X transceiver X status
show hw-module subslot X/X transceiver X idprom detail
Keep in mind that you should identify the link and substitute the X's with the proper values.
Thanks.
Marin Grabovschi
Alex Pfeil
Level 7
Level 7
We had an issue the other day where we were within the length that the SFP should perform at and the fiber optic cable was passing the test. We used a more powerful SFP and it corrected the issue.
