Prezados membros da comunidade.Alguém saberia informa qual é o MTBF (Mean Time Between Failures) do componente SPF Gigabit - 1000Base-LX modelo GLC-LH-SMD.Atenciosamente.Marcio Durig
Hello,I am new on networking and I need help from community if possible.I have a pair of Cisco QSFP 40/100 SRBD bi-directional transceivers that installed on Mellanox ConnectX5 100Gb Adapters, connected them via an OM5 LC type 1M (or 3M) fibre cable...
Is there a way to backup TCC+ database using TL1 commands? I checked TL1 command reference, but didn't see any commands that would allow it. I am running 3.4.2 code on TCC+ cards. I have over 40 nodes and it would be nice to automate backups. Thanks,...
Hi Folks, Good Day!If someone can help me out to get ONS 15454 M6 (TNC as node Controller) database backup other than CTC.We lost the Root login and need to reset the password to default, before this I need to backup the database using console or TL1...
Can the DCNM advanced edition (DCNM-SAN-M91-K9=) license purchased from CISCO manage the SAN32C-6 (9132T) purchased from IBM ?I don’t see any challenge though..but need a second opinion..
Good Day! I want to know if someone can advise how to come out of VX Works boot prompt of Cisco TNC card.I had connected console to the Secondary TNC card and then interrupt the boot process by pressing any key. Current prompt = [VxWorks Boot] : Now...
Hi all, Are there diagrams which shows typical recent use cases for ncs 1000 and 2000 series optical platform, including 1004 if possible. What they would usually be connected to etc. I see documentation which describes the equipment themselves and t...
Good morning, Need help.I have 6 sfp-10g-lr modules does not work with cisco ws-c3850-12xs, IOS 16.6.5.I have already activated the Service unsupported transceiver feature and in errdisable...Any idea?Grato.
Does this point to an issue with an SFP? We have a 4500-x vss stack, through which runs the heartbeat for a bunch of vrrp groups upstream, both routers have been going active due to loss of heartbeat. One of the switch uplinks has a tx power of -10db...
Dear all,I used the non-cisco transceivers on the A9K-8HG-FLEX-TR. They work normally for about 24 hours. Then I did the shut and no shut port action. And I get the following alarm:LC/0/2/CPU0:Jun 16 21:54:41.759 ICT: pfm_node_lc[268]: %PLATFORM-OPTI...
My company is in the early stages of designing a new space (about 100k sq ft) and our architects are pitching a PON instead of copper (most likely CAT 6a). I've never dealt with such a deployment and before I discuss with our IT services provider I w...
Hello. SFP-10G-LRM is currently not supported on C9200L series. Are there plans to support it? Is there any hardware incompatibility which prevents that? Thanks.
Dear all; appreciate your support to provide me with type of SFP single mode that support up to 120 km and compatible with cat 6509 or cat 4506
Recently I configured a 40Gb breakout link between two switches, on one side a Nexus 7706 w/a N77-M324FQ-25L blade, and on the other side, a Nexus 9336C-FX2 connected via a WSP-Q40GLR4L optic. This worked out nice and tidy with the four interfaces o...
Dear everyone, may I know where can I get the firmware v3.2.2 for ME4600 Series ONT, aka ME46XX ONT OS v3.2.2?I can find the release note, but I can't find where to download it. I have an ME4624-ONT-RGW, and it seems the firmware is broken, so I wou...
Subject | Author | Posted |
10-07-2024 12:40 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
