Cisco SFP-10G-ER - Is attenuator is must for < 20km
raghav.rai
I am planning to use Cisco ER SFP's (SFP-10G-ER) to connect a point-to-point circuit which is less than 10KM. I read in the datasheet SFP-10G-ER supports upto 40KM but it would require an attenuator to support less than 20km distance. Is it mandatory to have an attenuator? what will be the impact if I dont use attenuator ? pleas advise
Tks,
Raghavendra
marce1000
 - Check first actual reply from : https://www.reddit.com/r/networking/comments/5igacx/fibre_attenuators_how_do_to_figure_what_to_use/
                                    Personally I  would try without (first)
 M.
Joseph W. Doherty
"Is it mandatory to have an attenuator?"
Depends on how you mean "mandatory".
"what will be the impact if I dont use attenuator ?'
You receivers might receive a signal stronger than spec.  This may lead to data corruption.  Possibly if too, too strong a laser signal, transceiver Rx might be damaged.
Chances of the foregoing should depend how far you stray from spec.  So, for example, less risk for 19 Km vs. 1 Km.
Thank you both!.
in my case in the current scenario this circuit is terminated on a XENPAK-10G-ER+ module on a 6509.  We are refreshing 6509 with 9606R and the wan interface module will be SFP-10G-ER. I did check the received power on the current set-up which looks to be less which is -5db
                             Optical   Optical
            Temperature  Voltage  Current   Tx Power  Rx Power
Port        (Celsius)    (Volts)  (mA)      (dBm)     (dBm)
Te1/1         32.8       0.00      89.4 --    0.9      -5.0
and on the other side is a juniper device with 10G ER SFP transmits only 0.34db
  Laser output power                        :  1.0810 mW / 0.34 dBm
We dont know the exact fibre running distance. am I safe to assume power is less so it should work without attenuator? appreciate your spport
