10-16-2023 02:24 AM
Hi Everyone,
We have just had BT Fibre to property installed and the ONT uses an RJ45 cable. On our previous broadband it has an RJ11 that plugs into the back of the 887va. We use the router for external remote access so I need to keep this in our set up. Is there a way I can connect the RJ45 to the 887va?
Thanks James
10-16-2023 03:44 AM
yes you can use the WAN ports - based on the availability ports in the router and follow the BT DSL config to get IP address.
10-16-2023 07:09 AM
Thank you,
Apologies very much an newbie and this has been dropped on me. There are four Wan ports on the back do I use one of those or the port labelled console/aux? Once in the right port do I follow the advice below?
Thank you
James
12-07-2023 06:13 AM
yes connect Ethernet delivery to one of the ports and con figured your dialer using that interface.
example :
10-16-2023 03:47 AM
It seems your previous broadband was ADSL/VDSL based. Your new connection is ethernet based. You will have to migrate you configuration to ethernet.
As a an example you would create vlan 4 and configure the interface connected to the ONt to be int vlan 4. Then configure Interface vlan4 to be your Outside interface ( or NAT Outside interface if using NAT). You probably have a Dialer interface currently configured. If that is the case then you will need to bind that to interface vlan 4 e.g.
interface Vlan4
ip nat outside
pppoe enable group global
pppoe-client dial-pool-number 1
