09-28-2022 07:22 AM
I have a 10k fiber run I want to verify so I thought I would put a 4500X at each end. The fiber is connected to T1/1 on each 4500 and ports show up/up. I put a PC on T1/2 at each end and tried to ping between them but it doesn't work. I have not added any VLANs and show vlan brief shows all ports in VLAN1.
Do I need to create VLANs and/or Trunk ports to make this work?
Thanks, Kevin
Solved! Go to Solution.
09-30-2022 10:16 AM
My original goal was to test a 10k fiber run by connecting a switch at each end with a PC attached, then pinging or transferring files between PCs. I could not make it work with 4500X switches so I tried it with a couple spare 3750Xs and it worked as expected. Thanks to all that had suggestions. Kevin
09-28-2022 09:42 AM
- Check ip addressing schemes on both PC's (same subnet) and make sure the vlan subnet matches (if configured)
M.
09-28-2022 11:10 AM
The PCs are in the same subnet and all ports are in VLAN 1.
PC A IP: 10.100.0.5 Mask: 255.255.0.0 GW:10.100.0.1
PC B IP: 10.100.0.10 Mask: 255.255.0.0 GW:10.100.0.1
Pinging from 10.100.0.5 to .10 or from .10 to .5 gets no response.
Thanks, Kevin
09-28-2022 11:14 PM
- Does the gateway exist and or does it respond to ping ? Also post running-config of ports where PC's are connected.
M.
09-30-2022 08:43 AM
Hello Marce and thank you for your help.
I'm getting back to basics, so right now I have one 4500X with a PC on T1/3 and a PC on T1/5. No router, no gateway, and no connection to any other switches. Both PCs are in the 10.100.0.0/16 subnet. I cannot ping from one PC (10.100.0.5) to the other (10.100.0.10). Both PCs are linked and ports are up/up. I put both PCs on a basic trendnet enterprise SOHO switch and I can ping between them as expected.
Running config attached as a txt file.
09-30-2022 09:00 AM
Make sure each of the interfaces you are connected to is an access port (and set spanning-tree portfast just to make it immediately forward traffic vs. having to wait ~30 seconds).
conf t
int te1/3
sw mode access
int te1/5
sw mode access
end
wr mem
09-30-2022 10:11 AM
Thank you Marvin. I modified config as suggested and I still cannot ping between two hosts. I gave up on the 4500X and put in a spare 3750X and now it works. So I went back to my original goal of connecting two switches together with fiber and it all works end to end with 3750s.
09-30-2022 09:02 AM
- Configure the ports where the PC's are connected with : switchport mode host
M.
09-30-2022 10:12 AM
Thank you Marce. 'switchport mode host' is not available on the 4500X, so I gave up on it and put in a spare 3750X and now it works. So I went back to my original goal of connecting two switches together with fiber and it all works end to end with 3750s.
09-30-2022 10:01 AM
why you mention fiber ?
yes sometimes fiber have connectivity issue.
09-30-2022 10:16 AM
