Dell S28-25G-SR-SW-85C SFP compatibility with N9K-C93180YC-FX3H
Does anybody know whether Dell S28-25G-SR-SW-85C SFP compatible with N9K-C93180YC-FX3H?
thanks
6 Replies 6
marce1000
  - If a corresponding SFP is used at the Cisco switch  (same speed) ; and compatible
    according to Cisco Optics-to-Device Compatibility Matrix  then it should work ,
 M.
compatibility Q is exactly a challenge bc cisco matrix doesnt list any other SFPs/DACs except of its own.
  - Yes that's the purpose of the cisco matrix (pointing to compatible SFP's for a particular cisco switch (only)).
     'It does not matter' ; in the sense that for the other side the primary need is to use an SFP with the
     same speed and check it out,
 M.
do u consider test as a MUST for this case?
  - ALWAYS mandatory ; before business  and production use!
 M.
Anyone can share his experience with connecting N9K to Dell PowerStore from L1 perspective please?
were is Cisco AI?
