03-30-2022 07:12 AM
Hi everyone,
I have an SX550X switch and in the optics compatibility matrix it looks as MGBSX1 for the 1G SX compatibility.
I have a couple GLC-SX-MMD sfp modules laying around an I wonder if I can use these modules with this switch. I am confused since they are not listed in the compatibility matrix.
Also if these modules are not supported, can I use them after entering "service unsupported-transceiver command"?
03-30-2022 07:27 AM
its not in compatibility matrix. but in practical env, i have used GLC-SX-MMD in SG300 switch. you can give a try. console will show if module is detected successfully.
03-30-2022 07:44 AM - edited 03-30-2022 07:45 AM
GLC-SX-MMD - both the side you can test it, (since you have in hand)
i do not believe these model have the command.
