Interface up/up but does not pass traffic
arun.kumar3
Hi All, I have two OSR-7609 connected through GE-WAN(OSM-4GE-WAN-GBIC). The traffic does not pass between them even though the interfaces in both the routers show up/up. Both routers are using IOS 12.1(20)E3. To initiate the traffice i need to give the command router#hw-module module <slot> reset command. Once the module comes online the routers start passing traffic. But it stops after 48 or 72 hrs in operation. Please help this Problem.
Arun
spremkumar
Level 9
Level 9
hi arun
first ofall would suggest to go for a later ios ver like 12.2 instead of continuing with 12.1 and try ur luck.
if the problem still presists do raise a case with cisco TAC on this..
regds
spremkumar
Level 9
Level 9
hi arun
regds
Prem, this is has been documented in bug CSCef12193 and CSCsa48615. You are right this device needs an upgrade.
Nandri Thalaiva.
