ISL Brocade and Cisco
msingh08
Hello Team,
ISL between Brocade X6-4 Director/6510 Switch through  to 9132T Fabric Switch
Is it compatible/supported ?
I see no evidence, please advise..
Cisco's ISL and Broadcom's (Brocade) ISL are the same in name only. They are both proprietary, if you need to connect a Cisco 9132 to a Brocade 6510, you need to use dot1q encapsulation.
That said, even on Cisco equipment, I hardly see ISL anymore. It is all dot1q.
Check the document below for reference:
https://support.alcadis.nl/Support_files/Ruckus/ICX//Ruckus%20Best%20Practice%20Guide/Brocade%20ICX%20and%20Cisco%20IOS%20Deployment%20Guide.pdf
