In ISR 4431 router GLC-LH-SMD sfp not working,
error log
%TRANSCEIVER-3-INIT_FAILURE: R0/0: iomd: Detected for transceiver module in Gigabitethernet0/0/2, module disabled
%TRANSCEIVER-3-INIT_FAILURE: R0/0: iomd: Detected for transceiver module in Gigabitethernet0/0/3, module disabled
Router Version
Package header rev 3 structure detected
IsoSize = 556400640
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated 4AC6D592:81ABE151:08EA6841:FB1E6E6C:1A0956F4
expected 4AC6D592:81ABE151:08EA6841:FB1E6E6C:1A0956F4
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-BOOT_SRC: (rp/0): WARNING: Attempting to use bootflash for packages storage!
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2020 by Cisco Systems, Inc.
Compiled Thu 30-Jan-20 18:53 by mcpre
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
cisco ISR4431/K9 (1RU) processor with 1784246K/6147K bytes of memory.
Processor board ID
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
%INIT: waited 0 seconds for NVRAM to be available
Try below command :
no errdisable detect cause gbic-invalid or try "media-type sfp"
16.9.X is big buggy, try to Uplift to new verfsion of code and see if that fix issue.
