SFP-10G-SR-x vs SFP-10G-SR
HayamSalem79640
What is the difference between SFP-10G-SR-x and SFP-10G-SR?
Regarding the compatibility matrix, there are switches supported SFP-10G-SR-x and SFP-10G-SR & others support only SFP-10G-SR.
yes. SFP-10G-SR-x have extended temperature capabilities.
Good luck
KB
marce1000
 - FYI : https://www.optcore.net/archive26163/#:~:text=From%20the%20above%20comparison%2C%20we,but%20minor%20different%20some%20specifications.
 M.
According to Cisco, it is 10GBASE-SR SFP+ Module supports multirate including 10GBASE-SR, 10GBASE-SW and OTU2/OTU2e for extended operating temperature range. Different from SFP-10G-SR,
SFP-10G-SR -X supports OTU2/OTU2e.
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/data_sheet_c78-455693.html#CiscoSFP10GSRXmodule
Good luck
KB
So, this confirms that this SFP (SFP-10G-SR-x) is not the same of (SFP-10G-SR), right?
Good luck
KB
