03-04-2021 12:44 PM
Does the SFP-10G-LR only work with single mode fiber?
And should the port led be orange when connecting the sfp to a switch?
Solved! Go to Solution.
03-04-2021 02:20 PM
Yes, single-mode fibre only.
03-04-2021 02:20 PM
According to the following doc, that sfp works with single mode fibre.
Is the orange led on the port you have connected the sfp? it could be the port is in a disabled state.
John
03-04-2021 02:20 PM
03-04-2021 11:12 PM
LR - Long Reach -only single mode.
post more information, what is the device and configuration.
